I have 2 APs in my wireless network at home. I'm certain the routers are set up correctly as my Windows 7 PC is able to roam between the access points flawlessly. Also, my previous iPhone 4 was able to roam perfectly fine. So, my conclusion is that there is an issue with the phone. I've tried using the Wifi Roaming Fix app in the Play Store, but that doesn't seem to fix the issue either. Has anyone else experienced these issues and does anyone know of a fix? I am able to connect to the first router fine, but when I move away from it my phone still tries to connect to that AP even when the second AP has a much stronger signal strength.
Thanks in advance.
Thanks in advance.
