1. brandonx1000's Avatar
    So, I was playing Trivia Crack and during my loading screen I noticed very faint outlines of my clock in the upper right. Not anything too bad, I'll never really see it under normal use, but I guess AMOLED still needs some work
    12-28-2014 09:47 PM
  2. B. Diddy's Avatar
    One of the pitfalls of AMOLED screens. How long do you typically have the screen on at a time?
    12-29-2014 04:13 AM
  3. brandonx1000's Avatar
    Its my work phone, so maybe an hour a day
    12-29-2014 10:49 PM
  4. vzwuser76's Avatar
    I've had 5 amoled screen phones and 2 LCDs. I've only had burn in issues with two phones, a Galaxy S3 and a Droid Maxx. The Maxx came out of it, but the S3 is permanent. My burn in on both was the status bar, and it's noticeable on the S3. The others I didn't have issues with are the Droid Incredible (original), the Moto X 2013, and the Turbo.
    Anymore I make sure to switch my orientation 180 degrees somewhat frequently (I normally use my phones in landscape mode when browsing). That's seemed to take care of the issue.
    You can try the apps that display different colors in a cycle to try to fix the screen (red, then blue then green then yellow then white, then repeat). It seemed to help my Maxx but was no help on my S3. I think they only help if the burn in is slight.
    sharkita likes this.
    12-29-2014 11:35 PM
  5. sharkita's Avatar
    Switching orientation somewhat frequently is a good tip and something easy to do - thanks!
    12-30-2014 12:00 PM
  6. xweb10's Avatar
    Wow, burn in after the phone has been out for less than 3 months! That is concerning.
    12-30-2014 12:14 PM
  7. brandonx1000's Avatar
    Yeah, I use Waze daily and can already see the status bar on the right side of the screen under certain colors as well
    12-31-2014 06:55 AM
  8. xweb10's Avatar
    I have had my MAXX for more than a year and there is no burn. If this is how sensitive the Turbo is, I may have to return it...
    12-31-2014 01:01 PM
  1. get rid of empty pages in main screen
    By zivshosh in forum Samsung Galaxy Tab 2 10.1
    Last Post: 05-19-2016, 07:35 AM
  2. How do you turn off voice roaming in android 4.4.4 on MotoX?
    By ttobba in forum Android 4.4 KitKat
    Last Post: 03-09-2015, 05:58 PM
  3. How to dictate replies in email?
    By newuserneedshelp in forum Samsung Galaxy Note 4
    Last Post: 02-22-2015, 10:49 AM
  4. Can I upgrade the 4G SIM card in my Turbo?
    By Dr Lou in forum Ask a Question
    Last Post: 12-28-2014, 01:46 PM
  5. How do I recover missing folders in my Gallery App?
    By polkadotshorts in forum Samsung Galaxy S4
    Last Post: 12-28-2014, 10:15 AM
