1. carla3610's Avatar
    I've had this phone for 3 weeks and my biggest complaint is that people I talk to say I sound far away or that I sound like I'm talking through a tunnel. I do not use speaker phone. Not sure what the problem is.
    01-03-2015 12:57 PM
  2. 1Coopgt's Avatar
    Are you using a case on your phone ? If so what kind ? If you aren't using a case are you making sure the mic on the phone is near or pointed at you mouth ?
    01-03-2015 08:01 PM
  3. leehardballer12's Avatar
    ....or a poorly placed screen protector that is partially blocking the mics at the bottom of the screen.
    01-03-2015 08:05 PM
  4. 1Coopgt's Avatar
    Very true.
    01-04-2015 11:52 AM
  5. carla3610's Avatar
    I do have a cover on the phone but it does not cover the microphone part. That is located at the very bottom of the screen. I also have a screen protector on but it does not cover it either. I can turn my phone off and sometimes that will correct it but not always.
    01-04-2015 04:42 PM
  6. 1Coopgt's Avatar
    Interesting you said that restarting the phone sometimes correct your issue . You may want to try doing a factory data reset . Sorry I got nothing else .
    ChuckG73 likes this.
    01-04-2015 07:35 PM
  7. Ch4dders's Avatar
    Agreed, this sounds more like an issue with the phone itself, not a case/screen protector. I'd even consider called VW tech support. Maybe they can get you a replacement device.
    Posted from 64GB BN Droid Turbo
    01-05-2015 08:49 AM
  8. carla3610's Avatar
    Thank you.
    01-08-2015 04:42 PM
  9. carla3610's Avatar
    Update....I went online with Motorola for my complaint. He had me clear cache in the boot menu. Problem resolved so far.
    01-09-2015 11:13 PM
  10. D._Manley's Avatar
    That works wonders at times for other little glitches...add one more to the list. Thanks for posting. FWIW, my hearing is far from normal & my Turbo is louder than I actually require - I can hear OK in normal situations with the phone not touching my ear at all.
    01-10-2015 12:01 AM
  1. Droid turbo bends
    By Joshua Mastin in forum Ask a Question
    Last Post: 06-29-2015, 06:19 AM
  2. Replies: 6
    Last Post: 02-22-2015, 06:04 PM
  3. Motorola Starts Lollipop Soak Testing on Turbo
    By deesugar in forum Motorola Droid Turbo
    Last Post: 01-08-2015, 11:53 PM
  4. Why won't my Droid Turbo connect to wifi?
    By private hazzard in forum Ask a Question
    Last Post: 01-03-2015, 01:36 AM
  5. Why am I unable to use my mobile data?
    By Junaid Farooqi in forum Displays
    Last Post: 01-02-2015, 11:13 PM
