1. xybix's Avatar
    I have a new Turbo. I participate in a lot of conference calls using the same conference room code. To make it easier to dial in, I had it setup on my old phone (Razr Maxx HD) to send the room code after I connected the call. Worked great and I didn't have to memorize a long string and input it (while driving usually). Now, when I click ok to send the tones, they're sent so fast that it comes across as one tone and isn't recognized. Setting the tone length in the settings does no good - normal is still too short. I've tried putting commas (,) in between each number, but that takes sooooo long it defeats the purpose. Any idea what's going on or other way to send the tones? I've tried other dialers, but they all use the OS settings and don't do any better.
    01-07-2015 02:19 PM
  2. warrusty's Avatar
    Try turning Advanced Calling to the "off" position. I had the same problem after the latest update which enabled HD Voice and Video call. Go to settings/wireless & networks/Advanced Calling.
    01-07-2015 07:06 PM
  3. DatabaseMX's Avatar
    But if you turn off Advanced Calling, doesn't that prevent doing Voice and Data simultaneously ?
    01-09-2015 08:37 PM
  4. Eclipse2K's Avatar
    Yes
    01-13-2015 01:28 AM
  1. Replies: 13
    Last Post: 07-26-2016, 03:57 AM
  2. Can I rearrange Home Screens with the stock Lollipop launcher?!
    By Marco772 in forum Android 5.0 Lollipop
    Last Post: 07-20-2015, 07:55 PM
  3. WiFi interfering with bluetooth?
    By Joe Bloe2 in forum Samsung Galaxy Tab Pro 8.4
    Last Post: 01-09-2015, 05:39 PM
  4. What is the best music ap/database to work with Galaxy S4?
    By Philosfr in forum AT&T Samsung Galaxy S4
    Last Post: 01-07-2015, 05:47 PM
  5. Why won't my Lg lte connect with the web?
    By GlennSr in forum Ask a Question
    Last Post: 01-07-2015, 01:12 PM
