1. russel5150's Avatar
    I just noticed this, the only thing ive done recently is clear the cache and do the play store updates. It may have started a couple days ago but i just noticed it..
    Haven't done anything that should affect it...
    Anyway, i found it odd, and there isn't setting on this phone to change them lighting up or not..
    01-09-2015 12:35 PM
  2. JJ Jones's Avatar
    Have you checked them in a dark room? They won't light up when you're in a certain brightness level.
    Sent from my Ballistic Turbo
    01-09-2015 01:07 PM
  3. russel5150's Avatar
    Well they are working now.. I thought the room i was in was dark enough, apparently not lol
    01-09-2015 01:12 PM
  4. Furt's Avatar
    I had to pay for the Lux app to get the button lights to turn off and you did it for free?!?
    I feel cheated...
    01-10-2015 01:14 PM
  5. Dhawk1202's Avatar
    I feel cheated...
    The Lux app can turn off the back light of the navigation buttons?
    01-10-2015 02:55 PM
  6. NoahForeman's Avatar
    So can the free version of Darker. Set to 100% and check off turn of capacitive buttons.
    Posted via the Android Central App on my Droid Turbo.
    Dhawk1202 likes this.
    01-10-2015 03:39 PM
  7. Dhawk1202's Avatar
    You're the best!
    01-10-2015 04:59 PM
  8. nwasquad1's Avatar
    Didnt want to start my own thread so I'll post here. Recently noticed that the third soft key button (showing multiple windows) doesn't fully light up. It shows the 'front' window as lit but the 'back' window (which kind of looks like a flipped, sideways "L") is not. Tried rebooting a few times and it is not a 'darkness' issue like OP. Not sure how or when this happened or if it is normal.
    01-10-2015 09:39 PM
  9. Dhawk1202's Avatar
    There's already thread about this issue.
    01-10-2015 09:41 PM
  10. nwasquad1's Avatar
    If I had known that I would'nt have posted a message here. Can you link me to it?
    01-10-2015 09:57 PM
  11. nwasquad1's Avatar
    Bump for assistance
    01-12-2015 02:34 PM
  1. Why are my apps closing suddenly on my G S3?
    By Paulius Melinis in forum Samsung Galaxy S3
    Last Post: 01-10-2015, 10:47 PM
  2. Replies: 4
    Last Post: 01-09-2015, 01:46 PM
  3. Replies: 1
    Last Post: 01-09-2015, 08:33 AM
  4. Snooze button
    By pdaniel219 in forum LG G3
    Last Post: 01-09-2015, 07:20 AM
  5. Replies: 0
    Last Post: 01-09-2015, 12:20 AM
