1. mjordan68x's Avatar
    When I run programs (could be any of the location programs) gives me this error intermittently and continuously.
    "In a previous version of Android, you turned off the ability for Google apps to access your location.
    Turn it back on for all Google Apps?
    <Not Now> <Yes>"
    When I press yes or not now it keeps prompting. Even does this for Maps.
    System version 21.44.8
    Android version 4.4.4
    Thank you,
    ~Joe
    01-09-2015 03:07 PM
  2. Eclipse2K's Avatar
    Go to Settings>Google>Location and turn it on if its not.
    01-13-2015 12:30 AM
  3. mjordan68x's Avatar
    Eclipse2K - Thanks foryour feedback.
    I have already turned the location on and off but this prompt still occurs. I Need location on for maps, and a lot of other items.
    Why is my Droid Turbo prompting me to turn on the location everytime?-screenshot_2015-01-09-15-53-07.jpg
    This is really annoying, because it keeps popping up and the location is already on.
    Thanks,
    01-14-2015 02:19 PM
  4. Eclipse2K's Avatar
    You may want to try and clear your cache. Here is a write up by Motorola on how to do it.
    https://motorola-global-portal.custh...p/30,6720,9277
    01-14-2015 03:50 PM
  5. w9awx's Avatar
    Tried the clear cache steps and never can get the boot screen (#2) to show up.
    01-20-2015 12:47 PM
  6. doogald's Avatar
    Go into settings / location and turn it off. Then turn it on again - you'll get a couple of prompts that you have to agree to. Try saying yes to both of those, and see if that stops the prompts.
    Clear cache takes usually 10 minutes or so - you just have to wait it out. I think that you're giving up too soon.
    01-20-2015 03:56 PM
  1. How can I increase the headphone volume on my Nexus 6?
    By tharealcrayons in forum Google Nexus 6
    Last Post: 01-10-2015, 06:39 PM
  2. Replies: 2
    Last Post: 01-10-2015, 03:35 AM
  3. How do I make video calls on my LG G3?
    By JaymesPayten in forum Ask a Question
    Last Post: 01-09-2015, 03:18 PM
