1. xweb10's Avatar
    My Turbo is showing "Red" under "Mobile network signal" (battery history page) in places my old MAXX never had issues with. My battery is also draining rather quickly due to this. Has any one else experienced this? I tried "Global" and "LTE/CDMA" and it was the same.
    01-12-2015 11:54 AM
  2. Rukbat's Avatar
    1) The reason the battery is draining is that the transmitter is at maximum power when the receiver can't get an answer to a connection request, and it keeps making connection requests.
    2) You probably have a defective device. It's new? Bring it back and, unless they're having tower problems, or your account data is messed up, ask for a replacement phone. (Make sure anything you don't want to lose is either in the cloud [like a gmail account's emails] or backed up - they won't transfer the data for you.)
    xweb10 likes this.
    01-12-2015 12:49 PM
  3. xweb10's Avatar
    Thanks for the tips. It is rather new (December 21). This just started happening recently too.
    01-12-2015 12:53 PM
  4. JohnS305's Avatar
    I read about this problem on another forum and had the same thing happen to me http://www.droidforums.net/threads/l...unlock.278162/. One morning last week when I unlocked my phone I saw an error message pop up but it went away before I could read it. It was something about LTE. Then I checked and saw that I had lost network signal at some time. On the other forum some people were experiencing the same problem and one suggestion was to re seat the sim card. I wondered if the topic would come up here and now it has. Might be a Verizon problem.
    xweb10 likes this.
    01-12-2015 04:35 PM
  5. jkeben's Avatar
    I'm actually the OP for that other thread and reseating the SIM card has fixed it as far as I can tell. Since my original device had an issue with the screen, they swapped the SIM card manually and I'm sure that it where the problem first came from. If it comes back up though my next call is to Verizon.
    Sent from my Droid Turbo
    xweb10 likes this.
    01-12-2015 09:04 PM
  6. xweb10's Avatar
    I tried re-seating the SIM card earlier after reading that. A few hours later I cleared the cache and rebooted. Upon first boot I got the popup indicating something along the lines of "cannot find an network" or similar (it is so fast I dont have time to screen grab it)... It could be because my home is not in a 4G covered area and I use a network extender. That being said, my MAXX never had this issue.
    01-12-2015 10:53 PM
  7. JohnS305's Avatar
    I did the reseat too and everything seems fine. As far as I know the network drop only happened to me once. It was at home where I have 4G and I hadn't messed with the Sim card before at all. Seems strange that several people have suddenly started to have this problem. Makes me think it's not the phones but maybe some kind of network problem.
    01-12-2015 11:15 PM
  8. xweb10's Avatar
    I have advanced calling enabled. Anyone else? I am just trying to figure this out.
    01-12-2015 11:39 PM
  9. jdfrye's Avatar
    I have had this also happen to me about 3 to me a mabe it was after the advanced calling feature was enabled.
    01-13-2015 01:12 AM
  10. jkeben's Avatar
    I also have advanced calling enabled. I'm going to see if that makes a difference.
    01-13-2015 01:20 AM
  11. Eclipse2K's Avatar
    Is the Network Extended available for LTE? If not, maybe Advanced Calling which uses LTE calling is the issue.
    01-13-2015 01:27 AM
  12. JohnS305's Avatar
    I have advanced calling enabled. I have since I got the phone since the update was already out when I got it.
    xweb10 likes this.
    01-13-2015 09:32 AM
  13. xweb10's Avatar
    The extender have is 3G only.
    01-13-2015 10:23 AM
  14. ds728's Avatar
    I've noticed this problem too, and it seems to happen when I've temporarily been without service (e.g., underground parking garage). When I come back to the surface, it looks like the phone still doesn't see the signal for awhile, unless I wake up the Turbo manually. In a day, if I'm in my parking garage 2x for a period of <5 mins total, I still end up with ~8-10% "time without signal" by the end of the day. I've figured this out just by seeing that the two periods of 'red' signal are around the times that I would've been underground.
    I guess this is probably a software bug/nuisance, rather than a hardware issue given that I otherwise don't have signal problems when I'm above ground. Today's my last day for a full device return, though, so I'm wondering if anyone else can chime in.
    01-13-2015 12:08 PM
  15. xweb10's Avatar
    This seems to be about right. I am also at the end of my return window and debating.
    01-13-2015 01:48 PM
  16. xweb10's Avatar
    I turned off Advanced Calling and my signal has not gone "Red" at all in the same areas where it was "Red" the past 2 days.
    01-14-2015 12:41 PM
  17. JohnS305's Avatar
    I didn't turn off Advanced Calling and mine hasn't gone red either. I still wonder if it was (or is) some kind of network issues. It hadn't happened before then all of the sudden a few of us have it happen over the same period of time.
    01-14-2015 09:34 PM
  18. JohnS305's Avatar
    Revisiting this topic because I get the red no signal and error message on wake up on a fairly regular basis anymore, at least two to three times a week. Sometimes it's at work, where the signal is not good, if I'm in certain parts of the building with the phone in my pocket. That I can understand, but other times it's at home, when I look at the phone first thing in the morning I find that it had lost signal for a good portion of the night. I've gotten used to it and don't find any real problems but I wonder if anyone else is still getting the error?
    02-23-2015 09:53 AM
  19. xweb10's Avatar
    Do you have advanced calling enabled? If so try turning it off.
    02-23-2015 10:27 AM
  20. JohnS305's Avatar
    I shut it off for a day and it seemed good, but it may have been too soon to really tell. Now today I got the new software update which turned advanced calling back on. Maybe the update fixed the problem. I'll try for a few days and see what happens.
    02-24-2015 10:48 AM
  1. How to add a homescreen without apps/widgets?
    By ishortedenron in forum Google Nexus 6
    Last Post: 01-11-2015, 11:12 PM
  2. Does Samsung's Allshare cast work without a modem or router?
    By Vincent Carr in forum General Help and How To
    Last Post: 01-11-2015, 07:14 PM
  3. Replies: 1
    Last Post: 01-11-2015, 06:32 PM
  4. Replies: 4
    Last Post: 01-11-2015, 10:37 AM
  5. Wifi Signal
    By bojowaggie in forum Verizon Samsung Galaxy Note 3
    Last Post: 01-10-2015, 07:44 PM
