1. derh20's Avatar
    I am having intermittent connect problems with the hotspot. Has anyone else had this problem? Has anyone found a fix?
    01-14-2015 09:53 AM
  2. Sean Cogan's Avatar
    Yes, a few others have encountered this issue after the Advanced Calling update. Search. Also, look in the Motorola Droid Turbo owners forum.
    01-14-2015 08:03 PM
  3. Sean Cogan's Avatar
    Just spoke with Verizon Level 2 Tech Support. There is a bulletin out acknowledging a Mobile Hotspot connectivity issue caused by the Advanced Calling update. Verizon analysts are working with Motorola on a patch to resolve the issue. An update will be pushed out when the patch is available.
    So a patch is coming, but no speculation on the time frame.
    01-16-2015 05:00 PM
  4. Sean Cogan's Avatar
    It appears that OTA version update 21.44.12 has fixed this issue. My Mobile Hotspot is now working with no problems.
    02-23-2015 01:21 PM
  1. Why is my Note 3 draining when charging?
    By Ashley Durham in forum Samsung Galaxy Note 3
    Last Post: 10-09-2016, 02:43 AM
  2. Replies: 13
    Last Post: 02-13-2015, 09:06 PM
  3. More info on the HTC M9 Plus... Or whatever they call it.
    By GenTsoChicken in forum HTC One M9
    Last Post: 01-24-2015, 07:36 AM
  4. Tab3 7" Stuck on Android 4.1.2
    By sideshowbirdie in forum Samsung Galaxy Tab 3
    Last Post: 01-14-2015, 04:53 PM
  5. Amazing battery life on Zerolemon
    By Tex_Norseman in forum LG G3
    Last Post: 01-14-2015, 12:59 PM
