1. guitarmageddon's Avatar
    I don't like the feature of being able to wave my hand across the lock screen and the screen turns back on, showing alerts etc...
    How can I turn this off?
    01-14-2015 05:27 PM
  2. UJ95x's Avatar
    Welcome to the forums!
    You can turn off Active/Moto display in the settings for "Active notifications"
    01-14-2015 05:51 PM
  3. guitarmageddon's Avatar
    Hmm...I went to settings, then moto, then turned off notifications but that didn't fix it.
    01-14-2015 06:12 PM
  4. Sean Cogan's Avatar
    Go to Settings -> Moto -> Actions -> disable 'Approach for Moto Display'.
    UJ95x likes this.
    01-14-2015 07:20 PM
  5. Mattsg430's Avatar
    Settings, moto, display, uncheck moto display.
    Sent from my Droid Turbo
    01-14-2015 07:20 PM
  6. Heather Meadows's Avatar
    03-10-2015 11:26 PM
  7. Heather Meadows's Avatar
    Go to settings, assesability, dexterity and interaction, air wake up. Your problem should now be fixed! It sure helped me out! Good luck and best wishes.
    Heather!
    03-10-2015 11:30 PM
  1. Rooting and installing lollipop AOSP on your LG G Pad 8.3
    By SmItH197 in forum LG G Pad 8.3 Rooting, ROMs, & Hacks
    Last Post: 03-06-2016, 08:18 AM
  2. Samsung Galaxy Note 3 will not power on after update
    By dorothyrs in forum Verizon Samsung Galaxy Note 3
    Last Post: 01-14-2015, 08:47 PM
  3. What is the best smartphone I can buy for $200?
    By Pokalai in forum Ask a Question
    Last Post: 01-14-2015, 08:44 PM
  4. How to SIM Unlock Sprint device?
    By lVirus in forum HTC One M8
    Last Post: 01-14-2015, 06:19 PM
  5. Why can't I turn off proxy settings permanently?
    By Alex Kerr1 in forum Ask a Question
    Last Post: 01-14-2015, 05:10 PM
