The "Location found" notification is getting really old. Is there a way, short of disabling location services to get rid of it?
This!
Or disable... :/Yes there is a GPS Notifier app, but it doesn't allow you to uncheck notifications.
Nope. It can't be disabled. Only force stop, which is only useful for about 3.5 nanoseconds.I forget how I stopped mine from appearing, but trying touching on the notification from the drop-down. That will probably take you to where you need to be to disable the notification.
