1. MarysDroid's Avatar
    I am a relatively new Motorola Droid Turbo user. My phone is usually on either silent or really loud. I've found the "Sleep" mode which has been helpful and I see that there is a "Meeting" mode which is great. But is there a way that I can set the phone to just vibrate from 8AM to 6PM Monday through Friday? This seems to be such a simple thing and I'm wondering why this is not a primary option. Is there a way to do this that I am not seeing?
    Thank you!
    01-23-2015 10:35 AM
  2. Golfdriver97's Avatar
    Welcome to the forums. I can't remember if the Moto Asist app can have multiple silence entries, but there are apps that you can set up at certain times to go silent. Tasker is one (paid) and AutomateIt is another (free/in app purchases) Both can be set up for a time so that when you are definitely at work, the phone will go silent.
    Tasker: https://play.google.com/store/apps/d...ndroid.taskerm
    AutoMateIt: https://play.google.com/store/apps/d...It.mainPackage
    MarysDroid likes this.
    01-23-2015 10:53 AM
  3. silverback's Avatar
    Tasker does really well. Especially if there is a unique WiFi SSID at your work.
    Golfdriver97 and donsmith1964 like this.
    01-23-2015 11:42 AM
  4. bigwilliestyle's Avatar
    Setting Profiles is another good one. Have been using it for years.
    Golfdriver97 likes this.
    01-23-2015 12:34 PM
  5. djousma's Avatar
    I use Llama for this exact purpose. Works great, and is free.
    01-23-2015 12:47 PM
  6. doogald's Avatar
    The Assist has a feature that can make the phone silent while you have any of your calendars with events. So, if you make a calendar for work, put in a weekly repeating event that happens every MTWTF during your work hours, and set the assist app to use that calendar to silence your phone while you are in a meeting, it will do what you want.
    That said, those other apps are good, too... I've used all of them (except AutomateIt) at some point since I've owned an Android phone, they all will work for this purpose. But, if you don't want to install another app...
    01-23-2015 02:13 PM
  7. CharlieL3's Avatar
    There's a scheduling app that can report on the cell towers your phone is in proximity to. You can use that app (and I'm sorry I don't remember its name) to silence the phone when the phone gets close to that cell tower. If there is more than one cell tower near your work, the phone could go silent when it is close to both of them, thus narrowing down the area that the phone would go silent in.
    If your hours are fixed, Apps like Timeriffic can silence the phone at certain times. I use it to silence the phone every night and turn the sound back on in the mornings, at different times depending upon whether i go to work on those days.
    Feldhege and Golfdriver97 like this.
    01-23-2015 03:02 PM
  8. Feldhege's Avatar
    I user timerific and it works perfectly.
    01-23-2015 04:05 PM
  9. bfranker's Avatar
    I use MacroDroid to put my phone on vibrate automatically when I get to work. Many ways to do this but if you sit in the same spot and connect to WiFi at work you can use that connection. Or, if you are at work at the same time everyday you can set a time span. Or, you can have it go to vibrate when at a certain GPS location or if you don't have GPS enabled when a certain group of cell towers are being used. Worth giving a look as it does a lot more than that too
    01-25-2015 01:34 AM
  10. donsmith1964's Avatar
    I use Tasker to cut my volume levels to half when connected to my work Wifi. It works great.
    Sent from my Droid Turbo using Tapatalk
    01-25-2015 09:53 AM
  11. droidguy1964's Avatar
    I don't think that there is anything better than tasker for automation.
    jfoofoo likes this.
    01-25-2015 10:00 AM
  12. asif105878's Avatar
    01-25-2015 10:20 AM
  1. Replies: 78
    Last Post: 09-13-2016, 11:41 PM
  2. Replies: 4
    Last Post: 01-23-2015, 05:36 PM
  3. Why is my HTC One M8 stuck on the HTC One Boot Up Screen?
    Last Post: 01-23-2015, 10:29 AM
  4. Replies: 0
    Last Post: 01-23-2015, 10:05 AM
