1. silverback's Avatar
    So, I was in class, with my phone supposedly silenced when the voice launch chimed. It was at full volume and disrupted the class. Not good for my grade.
    So, is there a way to get the chime turned off when the phone is on vibrate...or get rid of it all together?
    01-23-2015 04:55 PM
  2. doogald's Avatar
    Turn off Moto Voice while you are in class.
    01-23-2015 05:22 PM
  3. silverback's Avatar
    OK, but why when the phone is on silent? It worked fine on the MAXX. Some things, like volume buttons, shouldn't require a work around.
    01-23-2015 06:53 PM
  4. doogald's Avatar
    I'm not sure - you'll have to ask Motorola that one.
    Another idea is to change the launch phrase to something that will never have a false positive.
    01-23-2015 06:59 PM
  5. silverback's Avatar
    It has a false positive on "Привет мой мобильник". So, I'm not sure how to make something less prone to false positives...?
    01-23-2015 07:22 PM
  6. zero3187's Avatar
    The chime and other moto voice things go by the media volume. If you silenced your ringer you'll still hear it.
    doogald likes this.
    01-23-2015 07:35 PM
  7. silverback's Avatar
    No, unfortunately, turning down ALL volumes (including media) is ineffective.
    01-23-2015 11:55 PM
  8. 1Coopgt's Avatar
    Why not set you classes up as meetings in your phone calendar then use Moto assist to silence the phone during meetings . It has the settings to do it .
    01-24-2015 12:32 PM
  9. silverback's Avatar
    I already have a class scheduler which does the same. Unfortunately, moto voice doesn't silence. The main point is that there exists no control over the chime volume that I can find...
    01-24-2015 01:19 PM
  10. silverback's Avatar
    Also, just tested. Voice ignores assist.
    01-24-2015 01:26 PM
  11. doogald's Avatar
    I wonder if it expects english language phrases; maybe that's why? Maybe you should try an English phrase. Maybe that will be better. In the meantime, I'd just turn the phone off during class, or turn off assist during class, until you've verified that it won't false launch.
    01-24-2015 01:48 PM
  12. silverback's Avatar
    I have tried several phrases. In English, Russian and German as well. I have been just shutting off the phone during class, which seems to be the only recourse.
    I'm going to complain to Verizon to see if they can push it up hill to get the app developer on it.
    jesta192 likes this.
    01-24-2015 02:02 PM
  1. icons/apps don't launch immediately after swipe unlock
    By greeknasty in forum Google Nexus 6
    Last Post: 02-23-2015, 06:55 PM
  2. Can the Hi Galaxy voice be a mans voice?
    Last Post: 01-23-2015, 03:31 PM
  3. Google Voice on Verizon
    By dusoccer10 in forum Verizon
    Last Post: 01-23-2015, 01:28 PM
  4. Replies: 2
    Last Post: 01-23-2015, 10:02 AM
  5. Replies: 0
    Last Post: 01-22-2015, 12:22 PM
