1. Will1524's Avatar
    So I've had the Turbo for about a month now and am extremely upset with the constant reboots. For the first few weeks the phone worked fine, nothing was out of the ordinary.
    However, within this past week the phone has started freezing... I'll be using it and then suddenly the screen freezes and sits there and reboots itself. It does this a few times a day and is really getting on my nerves....
    Any advice on what to do?
    01-24-2015 04:17 PM
  2. D._Manley's Avatar
    Clear the cache & failing that, have it replaced.
    01-24-2015 04:19 PM
  3. JJ Jones's Avatar
    Run it in safe mode for a day to see if it's a misbehaving app.
    Sent from my Ballistic Turbo
    01-24-2015 04:47 PM
  4. Will1524's Avatar
    Do you think Verizon would replace it just on my word? I couldn't make it freeze in store, it just kinda happens.
    01-24-2015 05:08 PM
  5. camachinist's Avatar
    Here's the VZW page on clearing the cache partition:
    Wipe Cache Partition DROID TURBO by Motorola | Verizon Wireless
    You may also find other tips on possible causes of freezing in that knowledge base and/or Moto's similar documents.
    If it doesn't randomly freeze and reboot in safe mode, then it's likely something added. My Turbo is almost stone stock with very few added apps or functions and it's been rock-steady since launch day. Good luck!
    01-25-2015 12:02 PM
  6. MA2GA28's Avatar
    Clearing cache should help. If not, probably a bad app install. You can run it in safe mode, or you can uninstall the apps you installed since it went wonky and see which is causing the problem.
    01-25-2015 03:11 PM
  7. jdfrye's Avatar
    Removing the command central widget from home screen fixed my stutters and freezing
    01-25-2015 04:55 PM
  8. Robin Hebert's Avatar
    Thank you
    11-11-2015 02:55 AM
  9. usmc0341NN's Avatar
    I am now on my third Droid Turbo 2 Within 4 months because each one is freezing. After the 3 phone having problems I asked to reset my contract with a new phone. Verizon told me I needed to pay $400 for my phone to end the contract And then spend another $600 for new phone so. Am paying 400 for a broken phone to get a new one that works. Does that sound Crazy to anyone else? I am not happy and Verizon has proven my phone is defective each time but they can't change the contract or the phone. They told me customer services was the only one who can help. This is how they hep by taking more money from the customers.
    09-08-2016 03:40 PM
  10. doogald's Avatar
    This could be helpful: How to Contact Executive Customer Service and Get Your Problem Solved
    I'd just *calmly* keep pressuring them to replace your phone.
    (I'm also quite sure that freezing phone problems are almost always caused by the apps you've installed. I'd think about doing a factory data reset and only reinstall the apps that you absolutely need. At the very least, restart the phone in safe mode and see if it continues freezing, which should show that it is, indeed, an app issue.)
    09-08-2016 04:10 PM
  11. mrtonk's Avatar
    I second the above post. My phone has never frozen, although every once in awhile it has run slow and hot.
    09-08-2016 07:07 PM
  1. Replies: 4
    Last Post: 05-04-2016, 06:53 PM
  2. Why does my Droid Incredible 4G LTE shut down for no reason?
    Last Post: 01-25-2015, 12:50 AM
  3. How can I sync my Droid and Kindle Fire calendars?
    Last Post: 01-24-2015, 01:04 PM
  4. Please help me! With my htc droid dna
    By victorjoseDLS in forum Verizon Droid DNA Rooting, ROMs, & Hacks
    Last Post: 01-24-2015, 12:42 PM
  5. Replies: 0
    Last Post: 01-24-2015, 11:08 AM
