1. anon(9228075)'s Avatar
    I activated advanced calling. With carrier too. Have kept it off but thought would turn on and give a go.
    I can't even get a call to connect. It says dialing then boom, call ended. Nothing.
    Doesn't it default if not in lte zone?
    01-29-2015 11:58 AM
  2. B. Diddy's Avatar
    You'd think that it would. Maybe you're in a borderline area, and it's trying hard to stay with VoLTE, but failing. Have you spoken to Verizon about this?
    01-29-2015 12:24 PM
  3. doogald's Avatar
    It should default to CDMA, yes. However, in a case like that, I would definitely toggle VoLTE off on the phone in order to complete the call, at least temporarily.
    Verizon has a FAQ: Advanced Calling FAQs | Verizon Wireless and they suggest exactly that:
    When I'm using Advanced Calling 1.0, what can I do to avoid dropped calls if I m in a weak 4G LTE coverage area?
    If you're in an area with a weak 4G LTE signal, you may want to consider temporarily turning off the VoLTE Call setting on your phone to avoid dropped calls.
    Note: Remember to turn it back on when you're in a strong 4G LTE coverage area to take advantage of HD Voice and Video Calling.
    B. Diddy likes this.
    01-29-2015 12:34 PM
  1. Note Edge dropping calls during every phone call! anyone else?
    By MrToneBoneZ in forum Samsung Galaxy Note Edge
    Last Post: 06-19-2015, 12:05 PM
  2. Replies: 1
    Last Post: 01-29-2015, 02:37 PM
  3. How can I do a video call from Moto G2, with 3G service?
    Last Post: 01-29-2015, 12:08 PM
  4. Replies: 6
    Last Post: 01-29-2015, 09:46 AM
  5. Calling wont work, need help
    By QuincyP1994 in forum AT&T Samsung Galaxy Note 3
    Last Post: 01-28-2015, 04:19 PM
