1. flybub's Avatar
    Hey everyone. My Turbo seems to have an issue with refusing to go into landscape. Box is checked for auto rotation in settings. I've done a restart as well as wiped the cache partition but nothing has worked. Any other suggestions what I can do?
    01-29-2015 10:11 PM
  2. B. Diddy's Avatar
    Try Sensor Box to see if the orientation sensor is working correctly.
    flybub likes this.
    01-29-2015 11:10 PM
  3. flybub's Avatar
    Thanks B Diddy. Ran sensor box and everything is pointing to a bad sensor. This will be my 3rd replacement each for a different issue. Rrrrgggghhhh frustrating
    01-30-2015 06:36 AM
  4. B. Diddy's Avatar
    I was going to "Like" your post, but there ain't nothin' to like about that situation.
    flybub likes this.
    01-30-2015 01:56 PM
  5. Karl Turbo's Avatar
    I dropped my Turbo a couple of feet (it has a protective case) and the sensor stopped working. How annoying.
    Fortunately I tapped the phone with my knuckles from a few angles and it started working again and has worked since (file this under the "neva know" category.)
    01-30-2015 02:56 PM
  6. flybub's Avatar
    Haha, its all good. Just a phone
    B. Diddy likes this.
    01-30-2015 05:06 PM
  7. 1Coopgt's Avatar
    Are you using the stock launcher ? If so the display will not rotate on the home screen . You need to use an alternate launcher to have it rotate on the home screen .
    01-30-2015 07:20 PM
  8. flybub's Avatar
    I'm using Nova. None of the apps would rotate. YouTube, chrome, gallery all stay portrait even when the phone is rotated to landscape.
    01-30-2015 09:52 PM
  1. Compass problem D855
    By mariusfilip in forum LG G3
    Last Post: 01-30-2015, 01:11 AM
  2. Replies: 1
    Last Post: 01-29-2015, 11:19 PM
  3. Replies: 2
    Last Post: 01-29-2015, 07:07 PM
  4. Replies: 0
    Last Post: 01-29-2015, 04:03 PM
  5. My camera is stuck on landscape?
    Last Post: 01-29-2015, 02:31 PM
