1. lgbalfa's Avatar
    does this phone come with a "special" charger to take advantage of the fast charging speeds or will my existing micro USB chargers from my droid maxx do the same as the original one that comes with the droid turbo?
    thanks
    01-30-2015 01:36 PM
  2. JJ Jones's Avatar
    Yes, it comes with the Turbo charger which allows for faster charger on certain devices.
    Sent from my Ballistic Turbo
    01-30-2015 01:46 PM
  3. lgbalfa's Avatar
    thanks for the reply back.
    i like to have extra chargers so i will have to pick up the turbo charger as opposed to the ones i currently have for the droid maxx.
    01-30-2015 01:52 PM
  4. teeitupmo#WN's Avatar
    As you probably have figured out, most microUSB ac or car chargers will charge the Turbo... but if you want the Rapid charging, like #jjjones said, you will need buy the Droid Turbo charger.
    01-30-2015 02:38 PM
  5. lgbalfa's Avatar
    i would like to buy an extra charger but they are expensive.
    $35 on the motorola website.
    ebay doesn't even really sell them.
    01-30-2015 06:05 PM
  6. teeitupmo#WN's Avatar
    With the battery life of the Turbo and the rapid charger on hand, in my opinion...a spare rapid charger is a waste of your money.
    Sent from my iPhone using Tapatalk
    01-30-2015 06:07 PM
  7. mobrules's Avatar
    With as long as the battery lasts I only actually charge every other night. But I use a regular USB charger. It still shuts off after topping off just like the turbo charger. I don't think it really matters. And 35.00 for a backup is too steep.
    01-30-2015 08:44 PM
  8. lgbalfa's Avatar
    good point.
    $35 for any charger is just too much.
    01-30-2015 09:24 PM
  9. dungoyle's Avatar
    Good news, you don't need a Motorola Turbo Charger to Turbo Charge your phone. I picked this one up from eBay for $23, and it's down to $19 now. I use it at work when needed, and I like it better than the Motoroa brand, Definitely more portable, and easier to carry in your brief case.
    Tenergy Turbo USB Universal Charger with Qualcomm® Quick Charge™ 2 0 Technology | eBay
    01-31-2015 09:08 AM
  10. lgbalfa's Avatar
    i heard the cord is pretty short for the oem one. how is this cord?
    01-31-2015 09:27 AM
  11. dungoyle's Avatar
    Honestly, I don't even remember if it came with a cord. It just takes a standard USB cable, so the world is your oyster on cord length; if you want a long one, buy a long one, or scrounge one from you collection if you're like me and have about a half million. SOME USB cables won't carry the "Turbo" current. I don't know why that is, but most of the ones I have used will. You'll know when you plug it in; the phone displays a message "Turbo charger detected" (or similar). Best of luck to you.
    01-31-2015 09:34 AM
  12. lgbalfa's Avatar
    i just received the tenergy charger that you recommended from ebay.
    thank you for the recommendation.
    02-10-2015 01:49 PM
  13. IrekJanek's Avatar
    What you need to check is the amperage rating on your charger. For the fastest charging it would have amperage rating at 3A. Quick Charge 2.0 specs are 5V (standard USB), 9V and 12V and amperage rating up to 3A. The bottom line: You can use the charger but the speed will depend on the output rating of the old charger.
    02-11-2015 06:38 PM
  1. Can the LG G Pro be updated to Lollipop?
    Last Post: 08-24-2015, 01:25 AM
  2. Replies: 1
    Last Post: 01-30-2015, 03:54 PM
  3. I-9502 bought from merimobiles, wont work in the US?
    By Liora Yukla in forum Samsung Galaxy S4
    Last Post: 01-30-2015, 01:22 PM
  4. Has anyone rooted the ZTE Grand X (Z933)?
    By Ken Regular in forum Ask a Question
    Last Post: 01-30-2015, 01:13 PM
