1. this_is_nascar's Avatar
    Looking for a suction-cup based mount for my Turbo. I want to use it to use for hands-free calls and possibly video recording what's in front of me. The ability to have it charging would be fine, but not mandatory.
    02-03-2015 04:48 PM
  2. tech_fan's Avatar
    I use Iottie. I have purchased several in the past and this seems to work the best. Fyi...look up the rules governing what you can apply to your windshield. State of CA won't let you put anything unless, its mounted to the lower left hand corner within a few inches from the bottom.
    So, I had mine mounted to the dash. That worked ok at tended to wiggle a bit and when it got warm outside, it would need to be reapplied. I wound up with a Satechi cupholder mount. That seemed to work out the best.
    02-03-2015 04:54 PM
  3. doogald's Avatar
    I agree - iOttie OneTouch XL. It's great, the suction cup will stick to anything, it's very easy to put the phone in the mount and also to remove it.
    02-03-2015 08:09 PM
  4. this_is_nascar's Avatar
    Thanks.
    Sent from my Droid Turbo 64-gig from Tapatalk.
    02-04-2015 02:45 PM
  5. this_is_nascar's Avatar
    ... before I order, you guys know for sure that it fits the Turbo and doesn't block the camera?
    02-05-2015 07:14 AM
  6. this_is_nascar's Avatar
    USER BEWARE: If you have the Verizon Shell Holster Combo with Kickstand on the Droid Turbo and expect to be able to use the iOttie Easy One Touch XL Car Mount, you'll be disappointed. The side clamps do not extent far enough to securely clamp the phone to the back-plate. The shell holster makes the Turbo too thick to be safely secured with the clamps. I had high hopes for this case, but it's not going to cut it for me. I feel the slightest bump while driving will allow the Turbo to come right out of this case and cause it tall.
    02-13-2015 03:46 PM
  7. MA2GA28's Avatar
    I also found the iOttie holders to not work well anyway due to the BN Turbo's design. They use a button compression system to lock the phone, but shoving the phone in there would put a lot of pressure on the BN. And if you don't really push it in hard, it teeters on the button, making it unstable.
    02-13-2015 05:54 PM
  8. this_is_nascar's Avatar
    So now my question is what is a good windshield mount that I can use for my Turbo?
    02-13-2015 06:27 PM
  9. MA2GA28's Avatar
    Honestly, I tried a few, and was unhappy with them all for one reason or another. Either they didn't hold the phone securely, had grips that covered/pressed the volume rocker, or just had shoddy construction.
    02-13-2015 07:17 PM
  10. KSDroid01's Avatar
    I'm using an iBolt Xpro Dock (only use it on long trips). It seems to be pretty well made and has functioned fine for me
    Posted via the Turbo
    Codger1212 likes this.
    02-13-2015 07:45 PM
  11. Codger1212's Avatar
    I-bolt is definitely the way to go.
    02-13-2015 08:24 PM
  12. this_is_nascar's Avatar
    Any other suggestions, since the iOttie OneTouch XL won't work properly with my current case?
    03-17-2015 11:17 AM
  13. eabaggot's Avatar
    I got a Scosche IUHW9 which has a flexible gooseneck and a clamp that holds the phone very securely. It also releases the phone easily with a button on the back of the cradle, and it does not interfere with either the sound buttons or the charging port. I saw it at Best Buy for about 20$ but have not seen it since, and it is not visible on the Scosche website, although the "Stuckup 4-in-1 Universal Mounting Kit" is close. My particular model might be out of production now.
    The window sucker is very strong, but the neck can wobble the teeniest bit, which can throw off the bluetooth link. I have it set so the phone is just over the dash, and have some foam stuffed between the cradle and the dash to damp vibration. It actually does not look bad. Overall, I am happy with it.
    A lot of windshield mounts are unsatisfactory if you are like me and have a really sloping windshield.
    03-17-2015 04:12 PM
  14. 1Coopgt's Avatar
    I have this in my Camaro Awesome .
    03-17-2015 06:30 PM
  1. Does anyone recommend Lollipop?
    By shadwellal in forum HTC One M8
    Last Post: 02-20-2015, 03:39 PM
  2. TYLT VU Wireless Charging Car Mount
    By ajc312 in forum Motorola Droid Turbo
    Last Post: 02-10-2015, 11:59 PM
  3. How can I make my Nexus 7 tablet a refrigerator mount?
    Last Post: 02-03-2015, 05:42 AM
  4. Car mount
    By jay_g in forum Nexus 4 Accessories
    Last Post: 02-02-2015, 08:22 PM
  5. Would any one recommend a lense kit?
    By Kikoshi in forum Samsung Galaxy Note 4 Accessories
    Last Post: 01-30-2015, 07:01 PM
