1. RJ_Butler's Avatar
    Has anyone played around with the secret codes you can put into the dialer? Specifically the *#*#759#*#* code. It brings up a RLZ debug UI menu, with an option to turn on OEM mode. Anyone have any clue what this does?
    *note* OEM mode is defaulted to off, I turned it on and nothing happened
    02-07-2015 04:41 PM
  2. kmf1's Avatar
    There used to be a list of all the secret codes once upon a time but I haven't looked at it for quite some time. No clue what your example does.
    02-07-2015 07:06 PM
  3. Eclipse2K's Avatar
    I'm wondering if that's similar to OEM Unlocker on a Nexus device.
    http://www.droid-life.com/2014/11/04...loper-options/
    02-07-2015 08:42 PM
  1. Where is the music file stored at on my Motorola Droid Turbo?
    By REezy Mac BrEezy in forum Motorola Droid Turbo
    Last Post: 11-30-2015, 06:21 AM
  2. What is the code to restore logo to Samsung Note 4 copy?
    Last Post: 03-13-2015, 10:27 AM
  3. Replies: 2
    Last Post: 02-09-2015, 02:00 PM
  4. What is the puk code for the Motorola Droid Razr mini?
    Last Post: 02-07-2015, 05:31 PM
  5. Why are my incoming calls showing +1 before the area code?
    Last Post: 02-06-2015, 04:49 PM
