1. anon(9228075)'s Avatar
    Can we make a wifi hotspot with the Turbo?
    My s4 would do it but can't remember if just a samsung feature or Android..
    02-17-2015 09:28 AM
  2. this_is_nascar's Avatar
    A WiFi Hotspot can be accomplished on the Turbo, only by paying Verizon a monthly fee. When/If root is available for the Turbo, you may be able to do it free.
    02-17-2015 09:32 AM
  3. doogald's Avatar
    If you have a shared data plan, or a single plan with capped data, the built-in mobile hotspot app should work fine. (I have an iPad on my shared plan so I just use that, with its much better battery, the few times I need hotspot access.)
    Only grandfathered unlimited data plan owners need to pay a $30 monthly fee.
    02-17-2015 09:41 AM
  4. this_is_nascar's Avatar
    Can you tell me more about this? I thought that my plan required me to pay $30 monthly if I wanted this feature. How would I know if I can get it for free? When I had my Razr Maxx, I used root and altered the database to not check for this permission. Not sure why it would be any different now, meaning the ability to get this for free. Please explain.
    02-17-2015 09:55 AM
  5. doogald's Avatar
    The More Everything plans, which give you unlimited talk and text and allow you to select a capped data plan, also give you hotspot an no extra charge.
    More Everything Plan - Verizon Wireless
    Enjoy Unlimited Talk & Text, Personal Wi-Fi Hotspot and Shared Data for up to 10 devices.
    It doesn't have to be shared - it can be an individual phone as well.
    02-17-2015 10:09 AM
  6. anon(9228075)'s Avatar
    ok thanks. Is it pre-installed app or must we download something from vzw?
    Edit: I found it - under setting go and then more....
    02-17-2015 10:45 AM
  7. anon(9228075)'s Avatar
    And auto correct got me on the title lol - HOTSHOT. I corrected the post but couldn't the title...
    02-17-2015 10:46 AM
  8. this_is_nascar's Avatar
    OK, thanks. I'll take a look.
    02-17-2015 12:08 PM
  9. I800C0LLECT's Avatar
    If it helps anybody... I used pdanet+ and foxfi on my g2 with laptop. I'll see if I can get it working on the DT. They are free and worked great when I needed mobile data for my computer. My phone wasn't rooted and on Verizon. I think it was android 4.2 though
    02-19-2015 08:49 AM
  1. Should I buy Xperia Z1? Touch and WiFi issues solved?
    By white_Shadoww in forum Sony Xperia Z1
    Last Post: 07-30-2015, 03:05 AM
  2. Replies: 1
    Last Post: 02-19-2015, 02:19 AM
  3. S5 5.0 Wiped Cache & Lost WiFi
    By savnout in forum Ask a Question
    Last Post: 02-17-2015, 08:13 PM
  4. Auto wifi/3g off - can i still stream radio?
    By Morten Bang Jensen in forum Android Apps
    Last Post: 02-17-2015, 06:05 AM
  5. How do I receive notifications when not connected to wifi?
    Last Post: 02-17-2015, 12:30 AM
