1. John Jackson15's Avatar
    Can you add home screens so you have more than 3? How
    02-18-2015 12:27 PM
  2. doogald's Avatar
    Drag an app icon to the far right of a home screen. That will flip to the next one to the right, or create a new home screen to the right of you are already at the furthest right screen.
    You can do that by dragging an icon already on a home screen or the dock, or open the app drawer and drag the icon from there. Or you can long press on an empty area of any home screen, which will show you the home screens a little smaller with a widget and app picker at the bottom. Again, you can grab either and drag them to the right edge of the right most home screen and it will create a new one.
    Conversely, if you remove the last icon from a home screen, it will disappear.
    02-18-2015 12:46 PM
  3. lgbalfa's Avatar
    if the homepage has 3 screens and the default is the first one, is there a way you can make the default the middle 2nd one?
    02-18-2015 12:48 PM
  4. CharlieL3's Avatar
    I don't believe so with the stock launcher. I use Nova, and three home screens with the middle one as the default.
    doogald likes this.
    02-18-2015 01:22 PM
  5. dungoyle's Avatar
    Correct. This road is well traveled. If you want the home screen anywhere other than page 1, you'll need another Launcher. Nova is widely considered the best. There are many other good ones out there, but honestly, Nova has probably the best reputation, and is very easy to use.
    02-18-2015 05:25 PM
  6. doogald's Avatar
    Action Launcher as of yesterday also now let's you assign a default home screen. I believe apex does as well. Along with the Google Now launcher, which requires the left most home screen to be default, I believe that these are the most popular launchers these days.
    02-18-2015 07:05 PM
  7. dungoyle's Avatar
    I can confirm Apex which I used for years, and still recommend, but as a close second to Nova.
    02-18-2015 07:08 PM
  1. Replies: 7
    Last Post: 11-27-2016, 06:09 PM
  2. "Ok Google" Hotword on every screen suddenly disapeared
    By Amorgeddon in forum Android 4.4 KitKat
    Last Post: 04-17-2015, 09:51 PM
  3. Privacy screen review
    By KahneFan in forum Samsung Galaxy Note 4
    Last Post: 02-23-2015, 09:20 PM
  4. How do I remove the last call from my phone screen?
    Last Post: 02-18-2015, 10:12 AM
  5. Does anybody know what is wrong with my phone? BLACK SCREEN
    Last Post: 02-18-2015, 08:01 AM
