1. this_is_nascar's Avatar
    On my Droid Razr Maxx, you would press and hold the Power + Volume Down buttons together for a few seconds to "reset" the phone by simulating a pulling of the battery. Is that function available on the Turbo and if so, what's the key sequence?
    Thanks in advance.
    03-01-2015 09:10 AM
  2. Golfdriver97's Avatar
    I was under the impression that just holding the power button down for about 10 seconds should do it.
    03-01-2015 09:29 AM
  3. dungoyle's Avatar
    Exactly correct sir. Just press and hold the power button, ignoring the usual pop-up display until the phone shuts down. Release the power button. It will power back up on it's own.
    Golfdriver97 and ScottyDog like this.
    03-01-2015 09:48 AM
  4. this_is_nascar's Avatar
    Awesome. Thanks guys.
    03-01-2015 01:04 PM
  5. Hgouck's Avatar
    I believe Holding the power button only is more of a soft reset. If you want to do what pulling the battery does press and hold the power and volume down for 30 seconds. First it takes a screen shot than powers off keep holding for the 30 seconds. The phone will power up with a menu. Choose normal start up.
    JMHO
    03-03-2015 05:21 AM
  6. doogald's Avatar
    JMHO
    No, the hold power button is the battery pull on the Droid Maxx.
    https://motorola-global-portal.custh...%2C6720%2C8882
    03-03-2015 08:16 AM
  7. doogald's Avatar
    No, the hold power button is the battery pull on the Droid Turbo .
    03-03-2015 08:20 AM
  8. doogald's Avatar
    Ugh. Sometimes tapatalk stinks.
    Sorry, here is the correct link for the turbo...
    https://motorola-global-portal.custh...%2C6720%2C9277
    03-03-2015 08:24 AM
  1. How do I update my HTC Wildfire S a510e 2.3.5to Jellybean?
    Last Post: 04-12-2018, 10:00 PM
  2. New Flappy Bird challenger in market to challenge you!!
    By Indra Kumar Verma in forum New to the Forums? Introduce Yourself Here!
    Last Post: 03-02-2015, 06:18 PM
  3. How can I change my background in Go SMS using my personal photos?
    By Adora Grace Lim in forum General Help and How To
    Last Post: 03-02-2015, 01:45 PM
  4. Replies: 1
    Last Post: 03-02-2015, 01:21 AM
  5. Replies: 1
    Last Post: 03-01-2015, 11:33 PM
