1. AC Question's Avatar
    My droid turbo powers itself back up when I put it on my wireless charger
    03-24-2015 09:17 AM
  2. VW Maverick's Avatar
    Welcome.
    There may be a setting enabled that makes it come on when connected to a charger.
    See if there is on in Settings.
    Mav.
    03-24-2015 10:51 AM
  3. doogald's Avatar
    It has to be powered on with wireless chafging in order to monitor the charge and stop charging when full.
    03-24-2015 12:24 PM
  4. Davidoo's Avatar
    Yes, doogald is correct. That is the only thing I don't like about it. I like to turn my phone off at night to charge but that can't be done as far as I know with the Qi.
    03-24-2015 12:29 PM
  5. Rukbat's Avatar
    It doesn't have to be - Motorola chose to design it that way. The charging circuit in the phone is separate from the phone itself. (My Note 3 stays powered off when charging, either through the microUSB port of the Qi receiver. So evidently it can be done with a Qi receiver, maybe not just with Motorola's Qi receiver.
    03-24-2015 12:34 PM
  6. doogald's Avatar
    Right, I'll clarify that I was talking about qi charging on the turbo. The phone will power on if it is turned off. As of now, at least, that behavior cannot be changed. It's possible a future upgrade could change that, but the Droid Maxx has been the same way since launch, so I suspect that Motorola will keep the turbo working the same way.
    03-24-2015 12:45 PM
  1. Do android updates slow down phone?
    By Oluwadare Oyadiji in forum Android 5.0 Lollipop
    Last Post: 04-01-2015, 07:29 PM
  2. Downgrading on Mac
    By NastyNeil in forum Google Nexus 6
    Last Post: 03-26-2015, 08:29 PM
  3. How can I get my Drive and Play icon back on my Note 4?
    By AC Question in forum Samsung Galaxy Note 4
    Last Post: 03-24-2015, 03:56 PM
  4. Replies: 1
    Last Post: 03-24-2015, 03:53 PM
  5. Why isn't my 4G data working on my Note 3?
    By AC Question in forum Samsung Galaxy Note 3
    Last Post: 03-24-2015, 12:55 PM
