1. AC Question's Avatar
    whenever I turn phone on, visual voicemail fault message comes on.
    04-08-2015 02:16 PM
  2. srkmagnus's Avatar
    Open system settings - applications - Sort by all - visual voicemail. Try to clear data and see if that fixes the fault message. If it doesn't, then there should be another option to disable the app from the same setting menu.
  3. srkmagnus's Avatar
    04-08-2015 02:42 PM
  1. Why won't my Samsung S4 turn on?
    By AC Question in forum Samsung Galaxy S4
    Last Post: 04-26-2015, 02:09 AM
  2. Hello Droids!
    By npj1966 in forum New to the Forums? Introduce Yourself Here!
    Last Post: 04-15-2015, 12:45 AM
  3. How do I delete AT&T live?
    By AC Question in forum HTC One M8
    Last Post: 04-08-2015, 02:52 PM
  4. Which Android is the best fit for me?
    By cyclezib in forum LG G3
    Last Post: 04-08-2015, 01:52 PM
