1. motorcycle_monkey's Avatar
    I seem to notice the transition from a cooler color to warmer when going from bright light to lower light. I especially notice it with white backgrounds or my keyboard, which is light gray. Anyone else experience this?
    04-08-2015 03:12 PM
  2. DLK1's Avatar
    Is is called Adaptive Brightness and can be found in Settings > Display and then enable or disable Adaptive Brightness.
    motorcycle_monkey likes this.
    04-08-2015 03:46 PM
  3. motorcycle_monkey's Avatar
    Is that different than "auto-brightness" where it dims in low light? I didn't realize it would change the color hue. I guess it makes sense, since redish hues are supposedly less stressful on you eyes in low light. Thanks!
    04-08-2015 06:17 PM
  4. motorcycle_monkey's Avatar
    I don't see that option in the Turbo menu under that path, just the auto brightness one and Attentive display to turn on when I look at it.
    04-08-2015 06:19 PM
  5. maxman1's Avatar
    Ummm... Not on Droid Turbo.
    tlacour likes this.
    04-08-2015 06:25 PM
  6. motorcycle_monkey's Avatar
    Is anyone else experiencing this issue?
    04-09-2015 11:24 AM
  7. 88horizon5speed's Avatar
    The only issue I have with the screen is that sometimes on a white website the white will appear to have a reddish hue to it, only the top of the screen though. Not terrible but nkticable to me.
    04-09-2015 01:40 PM
  1. Why won't my screen stop jumping?
    By andrusalo in forum Samsung Galaxy Note 3
    Last Post: 04-09-2015, 01:36 PM
  2. Fraternity to Sue Rolling Stone
    By Scott7217 in forum Politics
    Last Post: 04-09-2015, 07:52 AM
  3. Why is the android device manager unable to lock my phone?
    Last Post: 04-08-2015, 04:27 PM
  4. Is there are basic information on how to use Android available?
    By augs289 in forum General Help and How To
    Last Post: 04-08-2015, 04:22 PM
  5. Question on saving pics from Samsung's txt app
    By The Hebrew Barrister in forum Samsung Galaxy S6 edge
    Last Post: 04-08-2015, 03:05 PM
