Yeah, I know. It's bizarre. SO I have a couple phones. Well, quite a few. It started when I could not download books to the Turbo. It just put an exclamation point in the title and says sorry, try again later. I try again later for several days, and nothing changes. On the other hand everything works fine on my other phones, and I can log into Amazon no problem. So I tried uninstalling and reinstalling Kindle. This is not a complete uninstall of course since Kindle is pre-installed and unless you root, you're stuck with it. But after I uninstalled the updates it still would not work. So I nuked from orbit by wiping the phone and reinstalling Kindle (well, updating the built-in version). Well, THAT changed it. Now it won't take the password. It allows me to CHANGE the password, and I did that. But even after changing it (successfully it said) and verifying that the new PW worked on another phone and on my laptop, it still won't take it. It says that username/password combination does not exist.
I called Amazon support and, after fussing with it for an hour they said "Huh. Never seen this before. I need to talk to the developers." That was last week and I've had no contact from them since. I assume they just flushed the problem down the toilet and forgot about it.
At this point I'm out of ideas. The thing is it USED to work. Until a couple weeks ago when it decided to stop downloading books.
