1. slowmyke's Avatar
    I have the droid turbo 32g. If I am listening to something on headphones and someone calls, the in call volume will be wake-the-dead loud. I can try to adjust the volume either before answering the call or after answering, but it makes no difference. It is loud enough that is uncomfortable to keep the speaker against my ear. I'd say this happens about 75% of the time. I can't figure out why it occasionally works correctly. Does anyone else have this issue? Is there a fix?
    Fyi- I listen on headphones set to the lowest volume setting, so it's not a loud volume setting that's getting stuck when I answer. It's increasing to what I imagine is the max volume and won't decrease. I also take my headphones out to answer the call, in case that's a known issue.
    05-04-2015 10:20 AM
  2. doogald's Avatar
    I wonder if it's happening because you remove the headphones before answering the call? If so, that's a bug for sure. It'd be interesting to see if you started answering the call with the headphones in and then removed them after the call was engaged that the volume control worked normally?
    05-04-2015 01:18 PM
  3. slowmyke's Avatar
    I'll check it out the next couple times the opportunity arises. It never occurred to me to leave the headphones on and answer until this thread. I don't like using headphones to talk on the phone- if I have to hold it by my face to talk anyway, why not just use it like a normal phone?
    05-04-2015 02:06 PM
  4. slowmyke's Avatar
    That was quick. Volume does not adjust when transitioning from listening to headphones to a call regardless of leaving the headphones connected or not. The volume slider will adjust on screen but the actual volume remains extremely loud.
    05-04-2015 02:14 PM
  1. Non-OEM Bands in "pretty" colors
    By priceslss in forum Samsung Gear S
    Last Post: 11-18-2015, 07:33 PM
  2. Why can't I access images in the photo gallery?
    Last Post: 05-05-2015, 12:54 AM
  3. Lock Screen in Quick Settings in COS12
    By jhodgert in forum OnePlus One
    Last Post: 05-04-2015, 08:35 PM
  4. Replies: 0
    Last Post: 05-04-2015, 09:52 AM
  5. Replies: 0
    Last Post: 05-04-2015, 09:42 AM
