1. tony bag o donuts's Avatar
    So I finally got the turbo. I can adjust to the lower sound quality I guess but my signal strength is horrible.
    I am around 96-110 dbm while my note 2 was always in the 80s. I haven't had signal this bad since the gnex. I even changed mobile network from global to lte/CDMA and same.
    For the sum from the store yesterday.
    Thoughts?
    05-22-2015 06:10 AM
  2. Almeuit's Avatar
    Definitely odd -- Do you have any other phones that you can compare in the same spot (like side by side)?
    05-22-2015 11:12 AM
  3. Davidoo's Avatar
    I would consider going back to the store and asking for another Turbo. If you can show them the difference with other Turbos in the store that would help. My Turbo has a great signal, as high or higher than all other devices I've had before, including my GS3.
    05-22-2015 11:20 AM
  4. tony bag o donuts's Avatar
    Bought it used.
    I changed from global to LTE/CDMA at work and next to my note 2 its the same.
    The 1x is great its the 4g that's bad at times but works. No issues calling wise except one instance.
    Also 22% battery drain in 6 hrs par for the course?
    05-22-2015 11:40 AM
  5. jec11718's Avatar
    Bought it used.
    I think 3.7% per hour is pretty good... 6.5-7 hours sot for me! So I'm happy
    DRoID TuRBo this...
    05-23-2015 11:54 PM
  1. If I lose signal will not come back till I reboot
    By ttrain68 in forum Verizon Samsung Galaxy Note 3
    Last Post: 11-11-2015, 12:14 PM
  2. Very frequent Bluetooth disconnects
    By jalan94 in forum LG Watch Urbane
    Last Post: 09-24-2015, 09:06 PM
  3. An App or Widget that will Auto Drop Poor WiFi Connections?
    By captainbdsc in forum Ask a Question
    Last Post: 06-24-2015, 10:56 AM
  4. Nexus 5 no signal
    By myphonedontwork in forum Ask a Question
    Last Post: 05-21-2015, 06:55 PM
  5. Replies: 1
    Last Post: 05-21-2015, 12:48 PM
