Save big + get 3 months free! Sign up for ExpressVPN today
  1. jschlis's Avatar
    I would like to have my bluetooth headset read my texts with the ability to reply. Is there an app available or something built in the turbo that will allow me to do this? I currently have a Plantronics explorer 505.
    05-23-2015 09:00 AM
  2. mrtonk's Avatar
    I think the built in Moto app will do this.
    05-23-2015 10:16 AM
  3. jschlis's Avatar
    Which app would that be. Assist does not work with the turbo
    05-23-2015 11:31 AM
  4. TurboHope's Avatar
    Go to moto app, click the cog in the upper right corner, select the assist option and check the driving option
    05-23-2015 08:34 PM
  5. jschlis's Avatar
    Assist is not compatible with the turbo, works on the maxx but not the turbo.
    05-24-2015 08:15 AM
  6. tdelfie03's Avatar
    I use motto assist on my turbo just about every day. In order for it to work while driving you have to have high accuracy location turned on. If you have a Bluetooth headset paired it allows you to use the headset to respond to texts
    05-24-2015 09:05 AM
  7. TurboHope's Avatar
    Yeah it comes preloaded on the he turbo, hence the screen shot. Like tdelfie said, you have to have high accuracy mode on, but I also use it every day, with a plantronic headset, it works perfectly.
    05-24-2015 09:42 AM
  8. doogald's Avatar
    The issue with assist is that it only works while you are moving fast enough to be considered driving, or are at home. If you are walking about (say, walking to work from the subway), it won't help you.
    Also, I believe that assist cannot read texts that are mms messages. So, if you are part of a group text, it won't read those messages, even if they are all text.
    05-24-2015 10:08 AM
  9. TurboHope's Avatar
    Isn't there a function for the blind that reads out msgs, if you aren't using it while riding or driving that should do it.
    05-24-2015 11:16 AM
  10. jschlis's Avatar
    Thank you all for the input. Trying the app dragon and going to see how this works.
    TurboHope likes this.
    05-24-2015 05:24 PM
  1. Replies: 10
    Last Post: 05-24-2015, 10:37 AM
  2. Why is my Note 3 showing 'In a call' when connect to bluetooth in CRV?
    By AC Question in forum Samsung Galaxy Note 3
    Last Post: 05-23-2015, 06:49 PM
  3. Disable head phone jack
    By franticrx7 in forum Samsung Galaxy S5
    Last Post: 05-23-2015, 09:18 AM
  4. Replies: 1
    Last Post: 05-23-2015, 07:18 AM
  5. Replies: 1
    Last Post: 05-23-2015, 12:24 AM
