1. TurboHope's Avatar
    So I can get my turbo to connect to my Windows 8.1 PC. The question is how do I transfer files, and what else would this connection be used/good for? Thanks.
    06-01-2015 08:45 PM
  2. KSDroid01's Avatar
    I haven't used phone-to-pc over Bluetooth, but ES File Explorer will let you see another device and transfer files via Bluetooth. I've used it to transfer content between two phones.
    Posted via the Turbo
    TurboHope likes this.
    06-01-2015 08:58 PM
  3. doogald's Avatar
    AirDroid is also great for transferring files over wifi. I also use an app called dropsync to sync folders over Dropbox - it's the main way I transfer files.
    06-01-2015 09:48 PM
  4. TurboHope's Avatar
    Does airdroid work with only Wi-Fi, or with Bluetooth as well?
    06-01-2015 10:10 PM
  5. doogald's Avatar
    I don't know. You don't have WiFi at home?
    06-01-2015 10:20 PM
  6. TurboHope's Avatar
    At home and school. But at work or other places I can't use the WiFi to upload or download over a mobile phone for security reasons.
    06-02-2015 10:39 AM
  7. doogald's Avatar
    If BT doesn't work, I believe that you can turn on the hotspot on the phone and connect from the PC vis WiFi to the device. It's been a while since I've used the app, though. I basically don't need it.
    See AirDroid | How to use AirDroid without Wi-Fi or oth...
    (Plus there is a lot of info about AirDroid at AirDroid | Portal )
    06-02-2015 03:23 PM
  8. TurboHope's Avatar
    Yeah you can for sure, I use hotspot a lot. I'll try the file explorer on that hotspot tonight, thanks.
    06-02-2015 04:04 PM
  1. Replies: 2
    Last Post: 07-07-2015, 12:16 PM
  2. Replies: 4
    Last Post: 06-08-2015, 02:59 PM
  3. Replies: 1
    Last Post: 06-05-2015, 10:22 AM
  4. Different Android Wear Versions on Phone and Watch
    By Mr.-Incredible in forum ASUS ZenWatch
    Last Post: 06-02-2015, 09:58 AM
  5. Replies: 1
    Last Post: 06-01-2015, 10:33 PM
