DROID TURBO: Emergency Dialing Maintenance Release
lovecars
59
My Droid was running crappy and slow today, so I decided to restart it, and left it on my desk, half hour later I look at it and tells me Android is updating, and it's optimizing app 50 of 148....... ???? Will post here the final result..
Looks like it installed something from Verizon but Android version is still 4.4.4
lovecars
59
Re: My Droid Turbo is installing a big update...
I hate it.. I thought that it might be Lollipop.. arrggghhhh I hate you Verizon except we have a love and hate relationship..... :mad:
Now the notifications tells me that Google Spotlight Stories is "now supported on your device"
doogald
Trusted Member
Jan 3, 2010
4,425
55
The Droid Maxx just received an update this week that fixed this. https://motorola-global-portal.custhelp.com/app/answers/prod_answer_detail/a_id/105254
(The details of the OTA just said "stability improvements".)
There was a story about this on Droid Life a month ago: http://www.droid-life.com/2015/05/0...ntenance-update-coming-to-nexus-6-and-moto-x/
As you can see, it's also meant for the Turbo. I wondered if they would hold it for the lollipop update. If this is it, I guess not.
lovecars
59
This is sooo stupid, I just restarted the phone again and it;s telling me the same thing....Android is upgrading
I see a factory reset in my future... but have to wait for another 45 minutes for it to OPTIMIZE 148 apps.
Ry
Moderator Captain
Trusted Member
Nov 16, 2010
17,654
214
Please post the new System version when you get a chance.
doogald
Trusted Member
Jan 3, 2010
4,425
55
Definitely no reason to factory reset. On the Maxx even the baseband version was the same.
1Coopgt
641
61
28
Op probably has ART turned on in the developers option .
TJ Kelly Jr
112
If you have art turned on in developer settings it will do this every time, don't factory reset until you check that
TJ Kelly Jr
112
OTA updates for Moto phones do this on Dalvik as well. It's not ART doing this.
Yes, on an update, on the initial restart, not on every subsequent one. That is part of making sure the apps run on the phone with a new update.
If it is doing it on every restart then he probably has ART turned on. Mine, with ART turned on, runs through this optimization every time. Hopefully, once ART is built into the OS standard, it won't do this any longer.
lovecars
59
New system version is 21.44.12.quark_verizon.verizon.en.us
And yes I have ART on... Will change it back and restart it one more time.
TJ Kelly Jr
112
Mine is the same build number /system version..
When you take off ART it's going to reboot again and do the optimization (I think) and then it shouldn't do it again until an update is applied (like 5.1 not just an app update)
lovecars
59
Working great now... although I'm still sad that it was not Lollipoop.....
wei34
