1. AC Question's Avatar
    WHen i search for the blue tooth from my phone it comers up empty
    06-03-2015 11:50 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Which Plantronics device? Are you certain you've pressed whatever has to be pressed on the device to initiate the pairing procedure?
    06-03-2015 12:03 PM
  3. Viswanathan N's Avatar
    was the device you were searching for in discoverable mode? Which device are you searching for? May be you could try NFC pairing(if yuor other device supports it).
    06-10-2015 06:35 AM
  4. 1Coopgt's Avatar
    Did you read the instructions that came with the Bluetooth device . Usually works every time . And if you don't have them you can download them on the interwebs .
    06-10-2015 07:18 AM
  1. Why can't I log into Google Photos?
    By AC Question in forum Google Nexus 5
    Last Post: 04-16-2017, 01:20 PM
  2. How do I stop cell standby from draining my battery?
    By AzureFDemon in forum Samsung Galaxy S6 edge
    Last Post: 12-02-2015, 04:49 PM
  3. Replies: 1
    Last Post: 06-03-2015, 12:20 PM
  4. Why won't my videos show in dcim folder?
    Last Post: 06-03-2015, 12:14 PM
  5. Replies: 0
    Last Post: 06-03-2015, 11:30 AM
