1. TurboCommander's Avatar
    I am in need of a car charger that can charge 2 Droid Turbos at the same time. Preferably at the fast charge speed, you know, turbo charger detected, yes, that would rock! Is that just any 2.1A charger that will charge these fast or does it have to be something else to detect a turbo charger?
    In any event, if I plug two into a regular $9 dual port USB cig lighter adapter I either get very slow charging on both or I blow the internal fuse in the charger which is sometimes not replaceable. So in looking at chargers I see several that say they have one 2.1A port and one 1A port. Are there are with two 2.1 A ports? Is this what I need? If I could do one Turbo and one iPad or two iPads at the same time that would be super awesome!
    I know I could take turns but slow charging sucks and if not in the vehicle for long and two peeps want to charge, someone is screwed. I need dual turbo enabled ports! Any ideas?
    06-09-2015 01:31 PM
  2. Phoenix212's Avatar
    You need to get a charger that has is Qualcomm Quick Charge 2.0 certified. I have not seen a car charger that has 2 Quick Charge 2.0 ports but this one has 2 ports with 1 port being Quick Charge 2.0 compliant: http://www.amazon.com/Qualcomm-Certified-Aukey-Charger-Included/dp/B00LJT2EPK/ref=sr_1_4?ie=UTF8&qid=1433875188&sr=8-4&keywords=qualcomm+quick+charge
    If you find a car charger with 2 Quick Charge ports, do share with the rest of us.
    06-09-2015 01:41 PM
  3. jpdaballa's Avatar
    06-09-2015 01:47 PM
  4. TurboCommander's Avatar
    I just found a reference to the iVoler in the S6 forum here http://forums.androidcentral.com/sam...ml#post4455907
    Thanks!
    06-09-2015 01:59 PM
  5. Phoenix212's Avatar
    I could only find 1 review of the item on Amazon. If you buy it, let us know if it's any good. I am always wary about buying electronics products on Amazon that do not include Prime, just in case there is an issue down the road.
    Also, I could only find one review for that actual model on Amazon, the rest of the 88 reviews are for the various other chargers listed on the page.
    06-09-2015 02:15 PM
  6. staticK78's Avatar
    Motorola has a turbo charger for cars now... https://forums.androidcentral.com/e?...token=DI-zfC37
    06-09-2015 05:14 PM
  7. 88horizon5speed's Avatar
    I'm not sure how new or nice of a car you have, but without much modification you can wire in another cigarette port into your car going either straight to the battery with a built in fuse or into the fuse panel to an appropriate sized fuse port. That would make so the single port doesn't have such a load
    06-09-2015 05:25 PM
  8. TurboCommander's Avatar
    I'll make sure to verify the single cig lighter port can handle the max draw from the iVoler. The Moto car charger is single port and I definitely don't want two at that price. I ordered the iVoler and will report back.
    06-09-2015 06:08 PM
  9. rxgadget's Avatar
    Found a great multi USB car charger from Chotech on Amazon but only has 1 QC 2.0 and 3*2.4 mAh. Need car charger that can handle 2 Droid Turbos-uploadfromtaptalk1433893741925.jpgNeed car charger that can handle 2 Droid Turbos-uploadfromtaptalk1433893779388.jpg
    06-09-2015 06:49 PM
  10. tony bag o donuts's Avatar
    I have the ivoler. Other than a six foot straight cord thing is awesome. Nice snug fit, subtle blue light to indicate power. Definitely recommend it.
    06-09-2015 09:44 PM
  1. Replies: 7
    Last Post: 08-17-2016, 05:21 AM
  2. Should I buy a new Droid Turbo?
    By Issemann in forum Motorola Droid Turbo
    Last Post: 06-13-2015, 06:33 AM
  3. Replies: 1
    Last Post: 06-09-2015, 04:29 PM
  4. Android Music Player that lets me put songs in order I want?
    Last Post: 06-09-2015, 01:23 PM
  5. Replies: 1
    Last Post: 06-09-2015, 12:57 PM
