How do I disable the Motto voice on my Droid Turbo?
  • Start date Start date
A
AC Question
how do i disable the motto voice on my droid turbo
i hit the motto button on accident and now i have to talk to it to get this apps, i just want to turn the voice off and do things manually
Re: how do i disable the motto voice on my droid turbo
Go back into the Moto app and turn off the items you don't want. Having Moto Voice functioning does not mean that's the only way to interact with the phone.
Head into either the Settings app and choose Moto, or open the Moto app from your app launcher. Then press the cog icon in the corner and press Voice, then disable it from there. I should note Moto Voice does not change anything about how the phone is used. Talking is never the only way of getting something done.
I started the Moto Tutorial and now cannot turn it off. I cannot go back to home or settings ...it just reads to me whatever button I am touching. How can I reset it and go to turn off the voice reader? thanks.
What happens if you restart the phone? If long-pressing power doesn't bring up the power off dialog, holding the power button down for 10 seconds should restart the phone.
Hi,
It is very easy only thing you have to use two finger to swap the screen.
-Go to Settings
- Accessibility
- Motto Voice
- log off.
You have to keep stedy one finger on screen and another finger to swap.
Thanks
r3dpuk3
