1. BlackAudiA5's Avatar
    On my Turbo, I'm able to adjust the exposure (it's located on my shutter button). My wife just got a Turbo yesterday and this adjustment seems to be missing. Any ideas?
    Posted via my awesome Turbo!
    06-17-2015 10:11 AM
  2. doogald's Avatar
    In the camera app, swipe right from the left edge to expose the camera settings. Make sure that the control focus and exposure setting is turned on (it's the middle setting of the settings wheel, it looks like a finger pointing at a dashed rectangle.)
    If that doesn't do it, open the play store app, open my apps, and make sure that the camera app is up to date.
    06-17-2015 10:36 AM
  3. BlackAudiA5's Avatar
    I've checked that those settings are on. It just isn't there. I'll check the Play Store for updates.
    maxman1 likes this.
    06-17-2015 11:16 AM
  4. cbironman24's Avatar
    The exposure setting was added as an update.
    06-17-2015 11:25 AM
  5. BlackAudiA5's Avatar
    They changed the new Google camera. No dynamic exposure adjustment... just, "dark", "cloudy"... etc. Not even close to the old stock camera.
    06-17-2015 11:34 AM
  6. doogald's Avatar
    I was talking about the Motorola camera app, not the Google camera app, just to be clear.
    In the Google camera app I have, there is a three dot menu bottom right. Tap that and it exposes some controls at the bottom - the leftmost one is exposure, and it allows you to adjust exposure to -2, -1, 0, +1, or +2 stops.
    (Well, that's after you slide from the left edge of the screen to expose the camera settings, tap the gear icon that now shows up in the upper right, tap advanced and turn on "manual exposure".)
    06-17-2015 12:20 PM
  1. How to adjust screen colours on CyanogenMod 11?
    By CellTheUltimateAndroid in forum Ask a Question
    Last Post: 06-19-2015, 06:48 AM
  2. Accessability - Vision - Talkback, speech rate issue, how can I adjust it?
    By briandsdad1 in forum General Help and How To
    Last Post: 06-19-2015, 06:33 AM
  3. How can I adjust toolbar in verizon email
    Last Post: 06-17-2015, 07:57 AM
  4. Replies: 0
    Last Post: 06-12-2015, 12:08 PM
  5. Can't adjust data usuage
    By nickstoyz in forum Samsung Galaxy S5
    Last Post: 06-04-2015, 08:55 PM
