1. topsurf's Avatar
    Does anyone else have this issue? When I am on WiFi (nearly all the time) and I open an app, any app that uses WiFi I get this (screenshot below) a little triangle that seems to mean my WiFi isn't working. Unfortunatley, my WiFi has no problems and is working fine. Is there any way to prevent this? Sometimes the it times out and after 2 or 3 minutes I have to try to reload a web address or page again and then the triangle will disappear and the page/app will load. Any help or insight is appreciated. Thanks. Droid Turbo WiFi Delay-img_20150617_113616.jpg
    06-17-2015 11:40 AM
  2. doogald's Avatar
    The triangles are showing network activity. Down means receiving data, up means sending (or maybe it's vice versa?). You'll see them flash as data is requested and received.
    It's perfectly normal and does not mean that it's not working.
    06-17-2015 12:14 PM
  1. Why does WiFI connection for Galaxy 10.1 randomly fail?
    Last Post: 06-19-2015, 01:30 PM
  2. Why isn't my HTC Desire 500 searching wifi signals?
    By AC Question in forum HTC Desire
    Last Post: 06-19-2015, 12:50 PM
  3. Replies: 0
    Last Post: 06-17-2015, 11:11 AM
  4. Replies: 1
    Last Post: 06-17-2015, 03:34 AM
