1. Bruce Wayne 84's Avatar
    This phone is nice but the battery life has been miserable I've had it for a month and yesterday I was at 4% battery with only 2 hours of screen time and the battery screen says the screen is always using 33% of the battery. I have turned brightness to low and set timeout to 15 seconds and its still the same thing. I also wiped the cache partition and charged the battery overy night with the phone off and nothing changed.
    Do I have a defective screen that is using too much current? What can I do about this? I used to have the moto maxx and I never had an issue with it, easily made it through a day with much more use and had half the battery left at night.
    adayoff likes this.
    06-18-2015 11:49 AM
  2. Einsteindks's Avatar
    Higher-quality, fancy-shmancy screens are more power-hungry. Only thing I know to say.
    06-18-2015 11:53 AM
  3. jerrykur's Avatar
    Does the screen go dark? The turbo has a sensor that illuminates the screen when it sees motion. If you don't have your phone in a case it could be seeing motion around you or in your pocket.
    06-18-2015 12:54 PM
  4. I800C0LLECT's Avatar
    There's something else going on... My screen is usually close to 60%of total drain and I can get 5.5 hours of screen on time
    06-18-2015 12:57 PM
  5. Bruce Wayne 84's Avatar
    If the screen was on in my pocket I think the screen on time would be jacked up.
    If there is an issue how do I express it to warranty services? Won't they just say battery life depends on the user
    06-18-2015 01:05 PM
  6. I800C0LLECT's Avatar
    I think you have apps or something else draining your battery. Check the other percentages of use. Don't know if this helps but here's my screen shots from just a second ago...
    06-18-2015 01:39 PM
  7. I800C0LLECT's Avatar
    I've been browsing on the internet using my phone for quite a bit. The building network has been down all morning. I usually get home after work with about 75 to 80% left
    06-18-2015 01:43 PM
  1. Replies: 1
    Last Post: 05-10-2016, 10:27 PM
  2. Replies: 37
    Last Post: 06-30-2015, 05:17 PM
  3. Battery life is bad... again
    By kirnkorner2001 in forum LG G3
    Last Post: 06-19-2015, 10:10 AM
  4. Does it matter what 10.1 screen I use to replace an old one?
    Last Post: 06-19-2015, 02:01 AM
  5. Replies: 5
    Last Post: 06-18-2015, 12:51 PM
