- To me personally it sucks. I don't like how the search bar app marker and keyboard are white. And I especially hate the way they made the WiFi icon look it bugs the hell out of me and its very annoying. My phone has been laggy ever since the update and some of my stuff won't work properly. It's incredibly annoying hurts my eyes and gives me head ache. My phone was perfect the way it was. Is there anyway to go back on the update?07-09-2015 02:51 AMLike 0
- since the update each time my phone turns off and i turn it back on. it doesnt just turn on instead it goes to recovery menu and i have to start it from there its not huge but its very annoying none the less. Is anyone else having this happen? i tried a factory reset no fix07-09-2015 03:07 AMLike 0
1. Wi-Fi indicator is actually fine by me. I guess you got used to the tiers rather than a solid icon. However, it does show your signal strength and shouldn't be any more annoying than before.
2. The search bar can be removed by long pressing on the home screen, select Settings and selecting to remove it.
3. Google Keyboard is set to white by default on Lollipop but you're not forced to use it as such. Just go to Settings/Languages and Inputs/Google Keyboard/Appearances and Layouts. You have 4 options here including the one you're seeing by default.
4. Your phone shouldn't be laggy after the update. You have two options to solve this issue. The first one would be clearing your cache and the second would be a factory reset. A cache clear will not result in a loss of data. To do a cache clearing, follow the instructions in the topic I'm linking to. Post #9 is what you're looking for: http://forums.androidcentral.com/mot...ml#post452539707-09-2015 05:42 AMLike 0 -
- I've read that you would be able to but I believe it would require a special way of doing it. That's why I say I'm not sure if its even available as of yet.07-09-2015 06:45 AMLike 0
- Two questions / complaints. Fist is there anyway to get rid of the ugly white google search bar? or at lest have it be transparent? Second and this one is really bad. I need to know if you can turn of notifications that pop up. If I turn of notifications I don't even get the little icon in the status bar that I got an email, text or whatsup. I want the little icon but don't want the popup that shows who sent you the message and even some of the content. Very unprofessional when you are showing something on your phone and email messages pop up. I am a consultant and work for different clients and don't want clients seeing stuff.adayoff likes this.07-09-2015 12:26 PMLike 1
- I need to know if you can turn of notifications that pop up. If I turn of notifications I don't even get the little icon in the status bar that I got an email, text or whatsup. I want the little icon but don't want the popup that shows who sent you the message and even some of the content. Very unprofessional when you are showing something on your phone and email messages pop up. I am a consultant and work for different clients and don't want clients seeing stuff.
Totally agree and can't stand it myself. The fact that there is no control to use popup over ticker is a feature that should have never changed.
Posted via the Android Central App07-09-2015 12:37 PMLike 0 - Two questions / complaints. Fist is there anyway to get rid of the ugly white google search bar? or at lest have it be transparent? Second and this one is really bad. I need to know if you can turn of notifications that pop up. If I turn of notifications I don't even get the little icon in the status bar that I got an email, text or whatsup. I want the little icon but don't want the popup that shows who sent you the message and even some of the content. Very unprofessional when you are showing something on your phone and email messages pop up. I am a consultant and work for different clients and don't want clients seeing stuff.07-09-2015 12:42 PMLike 0
- What is the circle that looks like a contact on the notification pull down? I select that and it says no contact exists.07-09-2015 01:57 PMLike 0
- If you open up your contacts app, you will notice at the top there is a Me contact with a "set up my profile". If you set up your profile, this info will now pop up when you click on the contact icon in the notification bar. What is this good for? Beats me. I guess that is the better question.
Posted via the Android Central App07-09-2015 02:28 PMLike 0 -
- My Bluetooth headphones have a lot of drop-outs after the upgrade. :-(
There are also glitches with the Phone app ending a call.
Everything worked great for me before that. Love my Droid Turbo.07-09-2015 06:39 PMLike 0 - Anyone else having there phones turn on straight to bootloader like I am. Kind of annoying adds an extra step to turning on my phone
Posted via the Android Central App07-09-2015 07:42 PMLike 0 -
- I want to update everyone on the Bluetooth glitch where listening to music will force you reboot your phone because notification volumes at the highest setting play at medium volume.
Make sure you close the music application first whether it be SiriusXM or another music application. Then turn off the Bluetooth headset/disconnect from Droid Turbo. If I disconnected the headset first it always messed up, but doing it this way has been great so far. Will update if I have an issue.07-09-2015 09:08 PMLike 0 - This makes no sense. I did setup my profile however I can't think of why I would want to see my info with the selecting that icon.07-10-2015 10:02 AMLike 0
As a note, that issue was corrected during the last KK update we got. The issue is not present with L from what I've see.mrcraft2u likes this.07-10-2015 12:16 PMLike 1 - I've done the Lollipop update (seems appropriate cause it SUCKS) can not connect to wifi anywhere. If I scan it won't pick up wifi. Home or at office.
I have a Samsung Galaxy Note 3.
Help would be greatly appreciated.
Brett07-10-2015 11:08 PMLike 0 -
Here's a link to the Note 3 forum:
http://forums.androidcentral.com/samsung-galaxy-note-3/07-10-2015 11:19 PMLike 0 - So i just did a cache wipe to try and bring my battery life back to normal, and I was hoping the "Android is starting, optimizing apps" notification would go away but I still get that every reboot. Anyone have an answere?07-11-2015 06:43 AMLike 0
- Forum
- Motorola Android Phones
- Motorola Droid Turbo
DROID TURBO: 5.1 Lollipop Update
When will the Lollipop 5.2 update be made available on the Galaxy Note 4?
By lpcs1 in forum Android 5.0 LollipopReplies: 5Last Post: 01-07-2016, 08:06 PM -
G4 - Verizon software update 06-30-15
By dpham00 in forum LG G4Replies: 63Last Post: 07-19-2015, 08:11 AM -
New Verizon Update for S5 G900V
By Drunder40 in forum Samsung Galaxy S5Replies: 22Last Post: 07-01-2015, 10:43 AM -
When is the update on the Samsung Galaxy S 5 to 5.1
By AC Question in forum Ask a QuestionReplies: 1Last Post: 06-30-2015, 11:57 AM
