09-14-2015 07:25 PM
438 12345 ...
tools
  1. Tim Bell1's Avatar
    Downloaded and seems like it is a little faster no lag. No issues so I am not doing anything as far as factory reset
    07-01-2015 01:29 PM
  2. iamtron's Avatar
    I just got the update. I am not part of the soak test. Still exploring but wanted to confirm it is rolling out.
    07-01-2015 01:30 PM
  3. Njbrandon's Avatar
    Updated. No issues so far.
    07-01-2015 01:34 PM
  4. srkmagnus's Avatar
    Awesome! Let us know how the update is going for everyone once it's finished installing. For those not receiving the update just yet, be patient. Updates are typically sent out in waves and geographical location is not a factor. You'll receive the update shortly .
    07-01-2015 01:37 PM
  5. Njbrandon's Avatar
    Everytime i unlock the phone it goes to my contacts?
    07-01-2015 01:39 PM
  6. Bitterman's Avatar
    I grabbed the update over my lunch break. Everything seems to have gone smoothly. I also did wipe the cache partition after the update. Will have to check things through more thoroughly later when I'm not at work.
    07-01-2015 01:53 PM
  7. I800C0LLECT's Avatar
    Only one problem I noticed... My Bluetooth acted up and Pandora doesn't send artist or song title to my radio anymore *shrug*
    07-01-2015 01:53 PM
  8. joe_fresh's Avatar
    Wife is saying the home button no longer closes out apps when she is in say Facebook. She has to back arrow multiple times to exit
    Posted via the Android Central App Using my Galaxy s6
    07-01-2015 01:55 PM
  9. brancross's Avatar
    1. Can't change input by pulling down the input, nothing happened when ib clicked other inputs.
    2. Google services crashed.
    3. Much hotter than before, I don't play game on my phone so I never had issues about becoming hotter on my phone, but after upgrading it was much hotter.
    Attached Thumbnails DROID TURBO: 5.1 Lollipop Update-23281.jpg
    07-01-2015 01:59 PM
  10. GESWhoseBack's Avatar
    Mine warmed up during the actual download but cooled back down after completion.
    LinuxWeather likes this.
    07-01-2015 02:04 PM
  11. LinuxWeather's Avatar
    So far so good ... Some things I noted:
    1 - phone gets very hot during update, but cools back down as others said
    2 - took 9 min on WiFi, about 26 min on 4G to download (using a friends numbers for comparison)
    3 - I have 62 apps, took 11 minutes to "optimize" apps and overall seemed faster install than most precious ones
    4 - Google play services takes some time to settle down, you'll get pop ups to update it, just wait like 5 minutes and things should settle down.
    5 - I had no apps opened before the restart to install but once in Lollipop when went to open apps I had about a dozen sitting there so not sure what it reverts that back to after the install
    Overall so far seems benign and running smoothly ... Seems transitions into and out of apps and among apps is smooth, at first was jerky but after 5-10 min all's well.
    07-01-2015 02:09 PM
  12. jemcmichael's Avatar
    Downloading!
    Sent from my XT1254 using Tapatalk
    07-01-2015 02:13 PM
  13. Njbrandon's Avatar
    Figured it out. Swipe right opens dialer, swipe left camera, swipe up regular unlock. Pretty cool feature.
    07-01-2015 02:32 PM
  14. zen45's Avatar
    my wifi seems to be better it isn't dropping off like it did before, but my settings has a different look and I cant seem to find the info about my file system ! the update went smooth no hickups .
    07-01-2015 02:38 PM
  15. CharlieL3's Avatar
    Does Lollipop use the ART cache by default, or do you have to change from Dalvik?
    07-01-2015 02:40 PM
  16. vlok16's Avatar
    Got my update, so far so good, doing a cache wipe now but don't think I need to do an FDR, everything is working just fine... just have to get used to the new look
    07-01-2015 02:47 PM
  17. mrtonk's Avatar
    So my Google Play Services has been stuck on this updating screen for 30 minutes. This is after I stopped and restarted the process a couple of times. I will not have a chance to factory reset until tomorrow at the earliest. I know I saw some issues with Google Play Services somewhere, but I can't find it. Anyone have any advice?
    07-01-2015 02:49 PM
  18. berserker's Avatar
    Lollipop only uses ART.
    07-01-2015 02:50 PM
  19. GatsbyGlen's Avatar
    It eventually resolves itself. I'm not sure why, but it took quite sometime before this updated.
    07-01-2015 02:54 PM
  20. chadastrophic's Avatar
    Does anyone else notice horrendous lte speeds?
    07-01-2015 02:55 PM
  21. gherman222's Avatar
    What keyboard is that?
    07-01-2015 03:36 PM
  22. philly's Avatar
    I absolutely love the update.
    Yes Kit-Kat was fine, and worked. But I'm even happier with the phone now.
    the wait was ridiculous, but it is over.
    88horizon5speed likes this.
    07-01-2015 04:09 PM
  23. ktabel01's Avatar
    So far so good. Don't like the white Google search box or background in the app drawer. Also don't like they I have to use the bottom multitab button in chrome to look at my browser windows. Where did they button go from within chrome
    07-01-2015 04:19 PM
  24. ktabel01's Avatar
    Fixed. There is a new setting in chrome called merge tabs. It was on by default. Flipped it off and back to a tab button within opera
    07-01-2015 04:21 PM
  25. quantum tao's Avatar
    the colors make me want to scream. no way to change them.
    skyboxer likes this.
    07-01-2015 04:31 PM
438 12345 ...
  1. Replies: 5
    Last Post: 01-07-2016, 08:06 PM
  2. G4 - Verizon software update 06-30-15
    By dpham00 in forum LG G4
    Last Post: 07-19-2015, 08:11 AM
  3. New Verizon Update for S5 G900V
    By Drunder40 in forum Samsung Galaxy S5
    Last Post: 07-01-2015, 10:43 AM
  4. When is the update on the Samsung Galaxy S 5 to 5.1
    Last Post: 06-30-2015, 11:57 AM
