09-14-2015 07:25 PM
438 ... 34567 ...
tools
  1. 88horizon5speed's Avatar
    I have gotten that too and I think I know what it means. Say for example I have 4g on only, I turn on wifi, there is initially a ! next to the wifi icon while it connects. Then when you turn off wifi there is a ! next to the 4g symbol while it fully switches over. I think its because in older version there would be two color changes to show when its connecting and when fully connected. Lollipop theres only one color so the ! means its not fully connected yet
    07-01-2015 07:36 PM
  2. mvp4him3's Avatar
    Anybody else's Google search on the main page glitch to where it moves it almost out of screen at the top? Also has anyone tried ART?
    07-01-2015 07:39 PM
  3. LinuxWeather's Avatar
    my battery life seems better by a little.
    And yes I forgot to mention from time to time I am getting a google hangouts has stopped working notification, even though it is disabled. Not a big deal bug but a big nonetheless
    You probably need to update it even though it's disabled, since its got ties no doubt to part of the Google play services package its probably doing some kind of check-in. Try enabling it and updating it. See if errors go away. Unfortunately if you disable it will downgrade and you'll be back in the same boat most likely.
    07-01-2015 07:39 PM
  4. TiMar99's Avatar
    Gotta say, the overall speed and performance is much better vs. 4.4.4
    07-01-2015 07:40 PM
  5. JeremytheIndian's Avatar
    Effing ridiculous
    07-01-2015 07:47 PM
  6. Moo Cow's Avatar
    Which is a logical thought I've wondered about but then your last sentence is truth: I disabled it for I don't use it and well... Yeah...
    Also found that I cannot disable the emergency alert app. I can't remember if I could on KK or not. But I don't ever use that app and have no need for it. I turn everything I can off on it.
    07-01-2015 07:49 PM
  7. PapaGary's Avatar
    That's odd. My Lollipopped (5.1) Moto X (2013) has a provision for setting up a guess account. I can't imagine how I'd ever use it however.
    07-01-2015 07:50 PM
  8. Notajediyet's Avatar
    I hope Moto/Verizon took this opportunity to remove the dead, OEM installed apps...Softcard, Quickoffice, etc.
    QuickOffice is still there, but softcard is gone
    Posted via the Android Central App on my Droid Turbo
    maxman1 likes this.
    07-01-2015 07:54 PM
  9. jfoofoo's Avatar
    Wife is saying the home button no longer closes out apps when she is in say Facebook. She has to back arrow multiple times to exit
    Posted via the Android Central App Using my Galaxy s6
    don't have that issue.
    88horizon5speed likes this.
    07-01-2015 07:58 PM
  10. tony bag o donuts's Avatar
    What's your favorite scary movie? What comes to mind?
    The Fog.
    88horizon5speed and Bagua like this.
    07-01-2015 07:59 PM
  11. JeremytheIndian's Avatar
    Lollipop uses ART...
    07-01-2015 08:13 PM
  12. tdizzel's Avatar
    Everyone on lollipop has tried ART since its the only thing available on lollipop
    07-01-2015 08:15 PM
  13. ktabel01's Avatar
    That's what I've seen as well
    07-01-2015 08:26 PM
  14. StormnNJ's Avatar
    Downloading now.
    Are there any issues with using Nova backup after or do I have to set everything up again from scratch?
    07-01-2015 08:29 PM
  15. beeare's Avatar
    For the Hangouts issue:
    I have it disabled and I was still getting that message. I went in and force stopped it. and then I re-enabled it and disabled it again, followed by another force stop just in case.
    It hasn't happened since.
    07-01-2015 08:34 PM
  16. Ch4dders's Avatar
    Downloading now.
    Curious of this myself... Downloading once the kiddos get to bed.
    Posted from 64GB BN Droid Turbo
    07-01-2015 08:39 PM
  17. Namrobo's Avatar
    So far so good. Battery life does seem a tad worse, (91% with 40mins screen on time vs 1hr to 1:20 /10% before) but then again its just come off the install. Im a hard gamer also so i guess (hope not as iv had this phone 6months) my battery is at 80%longevity now.... Yeh gaming will kill your batter lol
    07-01-2015 08:50 PM
  18. ForsakenCrown's Avatar
    You can't disable emergency alerts in case there's an emergency, such as a murderer in your area, kidnapping, etc. Doesn't matter if you don't use it, you still can't disable it.
    07-01-2015 08:51 PM
  19. mikesmith's Avatar
    Anyone else's home button not working?
    07-01-2015 08:52 PM
  20. Moo Cow's Avatar
    I went in and unchecked every single box that could be unchecked that was checked by default. No extreme threats, severe threats, AMBER alerts, the turn on notifications is off, alert reminder is off (by default on that one), vibrate off, speak alert message off. I think the only thing I'd get would be a mandatory Presidential alert.
    So basically, the app is disabled. Nothing is going to come through essentially. And if there is a Presidential alert, somehow, I think we'd all know BEFORE the alert went out. Which means it is a useless app, and I should be able to completely disable it. But whatever. It is what it is, I suppose.
    07-01-2015 09:13 PM
  21. 88horizon5speed's Avatar
    One thing I'm curious about is how well the battery saver mode works. Before in KitKat I was getting typically about 2 days of battery life. I'm going to run with battery saver enabled. My only concern is how often it will allow email sulync etc. No one seems to be clear. Some make it sound like it just suppresses it for a longer time and some make you feel like you have to manually check everything
    07-01-2015 09:15 PM
  22. Moo Cow's Avatar
    I went in, force stopped, enabled, disabled, force stop couldn't be done again as it was grayed out. Also cleared data/cache. Now I will wait to see what happens. It'll pop up soon enough. I'll know by tomorrow for sure as I get it somewhat frequently. Hopefully your tips work.
    07-01-2015 09:15 PM
  23. Eclipse2K's Avatar
    So is anyone else getting the Google Hangouts crashed error (or similar) when it isn't even installed? I could reinstall and reinstall I guess but it is annoying. Of course it has quit working -- it isn't supposed to work by design!
    I haven't gotten the nerve to factory reset yet knowing I'd have to redownload everything and reset my phone how I like it but I may have to as my keyboard issue still exists.
    When I did a factory reset it actually asked if I wanted to automatically restore all of my apps. I selected yes and it redownloaded them all automatically. You lose all data though.
    07-01-2015 09:26 PM
  24. StormnNJ's Avatar
    Did the update no cache wipe or full and didn't have to restore anything. All screens, apps, everything stayed the same.
    07-01-2015 09:36 PM
  25. Aredubu's Avatar
    My phone is working beautifully since the update. It was working nicely prior to that as well. Not sure if it's just me, but my speaker volume seems a little louder when playing music.
    07-01-2015 09:37 PM
438 ... 34567 ...
  1. Replies: 5
    Last Post: 01-07-2016, 08:06 PM
  2. G4 - Verizon software update 06-30-15
    By dpham00 in forum LG G4
    Last Post: 07-19-2015, 08:11 AM
  3. New Verizon Update for S5 G900V
    By Drunder40 in forum Samsung Galaxy S5
    Last Post: 07-01-2015, 10:43 AM
  4. When is the update on the Samsung Galaxy S 5 to 5.1
    Last Post: 06-30-2015, 11:57 AM
