09-14-2015 06:25 PM
438 ... 45678 ...
tools
  1. mobrules's Avatar
    Anybody else's Google search on the main page glitch to where it moves it almost out of screen at the top? Also has anyone tried ART?
    Yes I have that happening too.
    07-01-2015 08:44 PM
  2. mlsanders's Avatar
    Only one problem I noticed... My Bluetooth acted up and Pandora doesn't send artist or song title to my radio anymore *shrug*
    I noticed in the Moto app in settings, there is a check box that says something about Bluetooth not sending proper information. You should look into that and see if it helps. I haven't had that issue, but I've only used PocketCast so far.
    07-01-2015 08:52 PM
  3. mvp4him3's Avatar
    Lollipop uses ART...
    Haven't had time to do research.... Fun thing about working I guess. Thanks for the info.
    07-01-2015 08:54 PM
  4. mlsanders's Avatar
    So far everything seems good to me. One small thing that is driving me nuts though is when using my smartwatch with Smart Lock, I still have to swipe to unlock. The old style on KK, it would go directly to my home screen when I hit the power button. I know its small, but its one extra step I'm not used to doing.
    07-01-2015 08:56 PM
  5. Ch4dders's Avatar
    So everything is amazing outside of Google Play Services giving me issues. It's telling me that it needs updated but when I open the Play store it provides me with options to deactivate or open, not update.
    Anyone else?
    Posted from 64GB BN Droid Turbo
    07-01-2015 09:16 PM
  6. StormnNJ's Avatar
    No but I am seeing the search bar appear when I hit the right button to close out apps. Nova has it turned off and it's not on the home screen. Only appears when closing apps
    07-01-2015 09:26 PM
  7. Ch4dders's Avatar
    Anyone else?
    Worked itself out. It downloaded on its own and now things are running smoothly.
    07-01-2015 09:36 PM
  8. beeare's Avatar
    I went in, force stopped, enabled, disabled, force stop couldn't be done again as it was grayed out. Also cleared data/cache. Now I will wait to see what happens. It'll pop up soon enough. I'll know by tomorrow for sure as I get it somewhat frequently. Hopefully your tips work.
    Interesting, mine was not grayed out afterward. Either way, it's been almost 9 hours and it hasn't happened since for me.
    07-01-2015 09:47 PM
  9. italianotampa's Avatar
    I noticed that when I receive a message my whole screen wakes up for a couple seconds instead of the moto display. The screens then turns off and then I can use the battery saving moto display. How do you avoid the initial wake up which shows you your message contents?
    07-01-2015 09:58 PM
  10. Wiseblood's Avatar
    Outstanding update. Not a hitch and silky smooth.
    maxman1 and ktabel01 like this.
    07-01-2015 09:58 PM
  11. 1901Madison's Avatar
    Go to settings, then display, scroll down and turn off ambient display.
    tcmeiss likes this.
    07-01-2015 10:00 PM
  12. xweb10's Avatar
    Amen - http://forums.androidcentral.com/mot...d-devices.html
    07-01-2015 10:01 PM
  13. italianotampa's Avatar
    I did but it the initial message or alert still wakes the screen.
    07-01-2015 10:06 PM
  14. travaz's Avatar
    Yes I got the Turbo Charge Notice at 11% this afternoon
    07-01-2015 10:08 PM
  15. irishlak's Avatar
    Before 5.1 benchmark test
    posted with the first phone I have not broken in 2 days , Droid Turbo lol
    Attached Thumbnails DROID TURBO: 5.1 Lollipop Update-screenshot_2015-03-17-13-18-44.jpg
    07-01-2015 10:38 PM
  16. irishlak's Avatar
    After 5.1 update benchmark test
    Attached Thumbnails DROID TURBO: 5.1 Lollipop Update-screenshot_2015-06-29-22-03-01.jpg
    07-01-2015 10:39 PM
  17. irishlak's Avatar
    The 5.1 update is running flawlessly no issues at all, I have been running on it for 4 days as I was part of the soak test. Any issues you find are more than likely due to your settings and or your apps were not up to date. Visual voicemail is working fine and yes I get the notification that I have a new voice mail. The chop for the flashlight is a bit tricky but if you grasp your phone tightly and do it it responds it just takes getting used to. You can also drag from the top of your screen pull down and a menu will appear with the flashlight or you can say OK Google now and say turn on flashlight. Go through the 5.1 tutorial and read how to optimize your experience.
    07-01-2015 10:47 PM
  18. Namrobo's Avatar
    One thing I'm curious about is how well the battery saver mode works. Before in KitKat I was getting typically about 2 days of battery life. I'm going to run with battery saver enabled. My only concern is how often it will allow email sulync etc. No one seems to be clear. Some make it sound like it just suppresses it for a longer time and some make you feel like you have to manually check everything
    Are you talking battery saver for attentive display? Or is there an actual saver mode now?
    07-01-2015 11:02 PM
  19. tvouge's Avatar
    It's a feature. Go into your battery summary in settings. It's in the menu on that screen.
    Namrobo likes this.
    07-01-2015 11:11 PM
  20. Namrobo's Avatar
    Ahh thanks!
    88horizon5speed likes this.
    07-01-2015 11:14 PM
  21. Eclipse2K's Avatar
    So today I'm not paying attention to battery since its been abnormal use because I did a factory reset. Tomorrow will be the real test.
    07-01-2015 11:31 PM
  22. mrcraft2u's Avatar
    Does anyone know what the Star up above means?
    Attached Thumbnails DROID TURBO: 5.1 Lollipop Update-screenshot_2015-07-02-00-14-31.jpg
    07-02-2015 02:15 AM
  23. mrcraft2u's Avatar
    Never mind... Found the answer...
    http://www.solvemix.com/index.php/an...tus-bar-solved
    07-02-2015 02:19 AM
  24. sdouglas3673's Avatar
    I used nova backup and had no issues...I did a factor reset
    07-02-2015 05:28 AM
  25. beeare's Avatar
    Is this will all your messaging apps, emails, anything more than just 1?
    Maybe it's an app misbehaving...
    07-02-2015 06:50 AM
438 ... 45678 ...
  1. Replies: 5
    Last Post: 01-07-2016, 07:06 PM
  2. G4 - Verizon software update 06-30-15
    By dpham00 in forum LG G4
    Last Post: 07-19-2015, 07:11 AM
  3. New Verizon Update for S5 G900V
    By Drunder40 in forum Samsung Galaxy S5
    Last Post: 07-01-2015, 09:43 AM
  4. When is the update on the Samsung Galaxy S 5 to 5.1
    Last Post: 06-30-2015, 10:57 AM
