LinuxWeather
So far so good ... Some things I noted:
1 - phone gets very hot during update, but cools back down as others said
2 - took 9 min on WiFi, about 26 min on 4G to download (using a friends numbers for comparison)
3 - I have 62 apps, took 11 minutes to "optimize" apps and overall seemed faster install than most precious ones
4 - Google play services takes some time to settle down, you'll get pop ups to update it, just wait like 5 minutes and things should settle down.
5 - I had no apps opened before the restart to install but once in Lollipop when went to open apps I had about a dozen sitting there so not sure what it reverts that back to after the install
Overall so far seems benign and running smoothly ... Seems transitions into and out of apps and among apps is smooth, at first was jerky but after 5-10 min all's well.
