beeare
Idle battery drain is amazing so far after day 3. 5 hours off the charger and only lost 2%. That seems to be the biggest improvement with the battery life so far.
Dude, read the forums; plenty of people find the camera completely unacceptable! I think it's OK, but not having OIS is ridiculous.
Read any forum. Any. Plenty of people find their phone's camera completely unacceptable.
Read any forum. Any. Plenty of people find their phone's camera completely unacceptable. Reality is that only one or two find the Turbo "completely unacceptable" in this forum.
Now back to the OP...
Well, that's the problem with absolutes. They'll always make a fool of you.
GeodudeFFP is the first I've seen who thinks the Droid Turbo's camera is "completely unacceptable." Not the great unwashed masses, nor "only one or two" in this forum.
I know that black and white is easier to process than when you add in shades of grey and some colors, but the Turbo's camera is really good at some things and not very good at others. It's the single reason I have a G4 now (and I miss a lot of stuff on the Turbo for sure...even the Lollipop update is more to my liking than the G4's take on it).
Why is it so hard to understand that experiences differ, and that means opinions are not all the same? With the lengths to which you've gone defending this camera, PowrDroid, I'd think you invented the thing or something.
Help! Just updated to Lollipop 5.1. Updated everything. Massive battery drain. 1% in 5 minutes! In KitKat 4.4.4, my battery life lasts for more than 2 days! Any solutions?
What's your cellular signal in dBm?
Settings > More > Cellular Networks > Network Type and Strength
When did you update? It always takes a few days for battery life to settle in. My first charge after updating didn't get me through a whole day, but now my battery life is a little better than it was with kit kat. It just took a few days to get there.
Weirdly enough with this particular update my battery performance seemed to improve immediately.
Usually it does seem to take a few days to settle in.
So overall is it safe to say this update was worth the wait?
Virtually problem free, and better performance/benchmark seems to already be the consensus.
Also since nobody mentioned it, accessing recovery commands has changed. Instead of Vol up key for 15secs then power, its now Power for like only a couple seconds then Vol up & release. Just like the MotoX!
I hate when a company takes something people like and get rid of it for no good reason. I get even angrier when TV networks cancel good shows (I'm still miffed Constantine got axed).
Also, yes, there is a way to enable a battery number but it requires an application that you can uninstall afterwards. It basically changes a setting in Android that's available underneath. It's made by an xda developer and can be reverted back. The only issue is the number is rather small
So an app is needed but it doesn't actually do anything except enable a feature already there. I leave it on even though it's tiny. In KK it was white text so you wouldn't see it unless below 50% or so. It changes with LP.
