1. mobrules's Avatar
    Tasker doesn't work
    07-01-2015 04:22 PM
  2. Ry's Avatar
    Tasker doesn't work
    Could you elaborate?
    07-01-2015 05:43 PM
  3. mobrules's Avatar
    Sure. The app was set up to shut down background data and disconnect 4g when the screen timed out as a trigger. Then when the screen wakes up it would reconnect 4g and sync background data. After the update it does nothing. Paid version too.
    Thanks for asking. I would find it hard to believe its a lollipop issue because it works on my nexus 7 and nexus 10. And suggestions would be appreciated.
    07-01-2015 06:16 PM
  4. tony bag o donuts's Avatar
    Stupid question. Did you open app and accept new tos? Mine wasn't working until I cleared that screen.
    07-01-2015 07:03 PM
  5. mobrules's Avatar
    Not stupid at all. I did. But yours is working?
    07-01-2015 07:31 PM
  6. droidguy1964's Avatar
    Tasker doesn't work
    Yes it does.
    07-01-2015 07:32 PM
  7. mobrules's Avatar
    Droid guy are you rooted?. I have the paid version of Tasker
    07-01-2015 07:50 PM
  8. mobrules's Avatar
    I'm just wondering if there's some settings g I need to change or possibly reinstall tasker
    07-01-2015 07:53 PM
  9. tony bag o donuts's Avatar
    Yep. I have the task to make it say charging activated when plugged in. Worked on qi charger.
    07-01-2015 07:54 PM
  10. droidguy1964's Avatar
    No root. Did you fdr after going to 5.1? Wipe cache partition and if that doesn't work then fdr. You should probably fdr anyway after the update.
    07-01-2015 08:23 PM
  11. mobrules's Avatar
    Did cache wipe. I'll try FDR this weekend. Thanks guys.
    07-01-2015 09:41 PM
  1. Replies: 7
    Last Post: 09-20-2016, 12:58 PM
  2. To encrypt or not to encrypt?
    By netmouse in forum Ask a Question
    Last Post: 07-07-2015, 11:42 AM
  3. "HERE" (From Nokia) for android.
    Last Post: 07-01-2015, 06:52 PM
  4. Replies: 1
    Last Post: 07-01-2015, 06:05 PM
