Eclipse2K
Is setting someone as priority just checking the star in their profile? I didnt know if that did it or if there something else i needed to do.
Never mind i found it lol
Correct, star them in your contacts. Then when you set priority mode they can do as the profile states. Remember though, if you want them to ring while in priority mode, do NOT lower your volume! You must leave the ringer on. If you're unsure if you've done it correctly, call yourself from another phone that's set as a priority and see if it rings. To verify others won't, use the same phone but *67 in front to restrict. It should be silent.
