1. Tmsrise's Avatar
    So now that the update is out to all users and we can talk about it. Anyone notice the OEM unlock in the dev settings? This means the bootloader is unlockable and full root is easier right? Or am i just a retarded monkey? I made a vague post before as to not breach the soaker agreement.
    07-02-2015 04:04 AM
  2. JJ Jones's Avatar
    Unlock code is still needed from Moto. Big Red won't let them give it to us.
    Sent from my Ballistic Turbo
    Kyle Beroney likes this.
    07-02-2015 09:38 AM
  3. 88horizon5speed's Avatar
    I typed in my phones password and it unlocked it
    07-02-2015 05:11 PM
  4. bkeaver's Avatar
    You typed it in where?
    Sent from my XT1254 using Tapatalk
    07-02-2015 07:04 PM
  5. udazavlanje's Avatar
    Just curious where /how did you get it, because it's usually device specific.
    via AC App on
    VZW Moto X 2014/ DE 2013/ N7
    07-02-2015 07:09 PM
  6. 88horizon5speed's Avatar
    its in the developer settings
    07-02-2015 07:49 PM
  7. Clocks's Avatar
    I think the option simply allows for a user accessible setting to prevent unlocking (like if you lost your device). It doesn't overwrite any manufacturer restrictions.
    07-02-2015 09:50 PM
  8. Bob Maida's Avatar
    Excellent update no bugs in mine. Well worth the wait
    07-02-2015 11:01 PM
  9. Kyle Beroney's Avatar
    What I found when selecting this option on (which no one seemed to mention) is the dialog box that comes up after selecting it on. The box basically says that device protection will be disabled while the setting is on which could mean a lot of different things. It sounds like it is an override of built-in security software provided by Motorola and Google for development purposes (or rooting). I'd have to research it more, though.
    10-18-2015 01:34 PM
  10. Johninfla's Avatar
    We have 2 Droid Turbos, one has this setting the other doesn't. The one that does has had many issues since the update the other doesn't not sure if that has anything to do with it...when working properly this is a great phone. I'll have to see if that setting has any real value. I've had a few Motorola phones I've rooted, but the issues with this one only after a few weeks, has me worried about trying to root it while under warranty.
    10-24-2015 04:39 PM
  1. Replies: 3
    Last Post: 10-06-2015, 04:02 PM
  2. Why does my keypad jump to English all the time?
    By Jennifer Reuben in forum General Help and How To
    Last Post: 09-04-2015, 12:02 PM
  3. The step counter isn't working
    Last Post: 07-03-2015, 01:10 AM
  4. Replies: 2
    Last Post: 07-02-2015, 03:46 PM
  5. Replies: 1
    Last Post: 07-02-2015, 11:55 AM
