1. Kenneth Pierce's Avatar
    Droid Turbo
    Android 4.4.4
    When charging, it will not stay off. Tried shutting it down with the pop-up menu and by holding the power button for 30 seconds. Shuts down and boots right back up. If the phone is off and then I plug it in, it starts up. This happens when plugged in to a computer, a 3rd party charger, or battery pack, but not when plugged in to the turbo charger that came with it. When plugged in to the charger that came with it it will go to the charging screen. All of this is with the same cable. So the cable type isn't the issue. Well, could be. The cable is a data cable and I don't have a power only to test with.
    07-04-2015 03:16 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! This probably won't help, but go to Settings>Developer Options, and make sure Stay Awake is not checked.
    07-04-2015 05:43 PM
  3. Kenneth Pierce's Avatar
    Thanks for the welcome. Stay Awake is off.
    07-04-2015 07:44 PM
  4. rxgadget's Avatar
    When you hold the power button down for a bit the phone will shut down and restart automatically. Best way to shut down is power button till menu and click power off. Try that to see what happens
    Sent using my Verizon Turbo charged 64GB Ballistic Nylon phone unfortunately with a case on back
    07-04-2015 10:28 PM
  5. Kenneth Pierce's Avatar
    Did that as well as part of my tests before posting. Same results.
    07-05-2015 12:28 AM
  6. doogald's Avatar
    I am pretty sure that this is by design. The phone powers itself on so the the internal service can monitor the charge and prevent battery pack overheating. They must have built in something special for the turbo charger only that can monitor charge without the phone being powered on.
    07-05-2015 06:17 AM
  7. Kenneth Pierce's Avatar
    Which is funny because I want to use a charger with lower amps to keep the battery cooler; Gets quite warm with the turbo charger. Takes a really long time from 0% with a 1amp charger, but a typical day only gets down to 50%.
    Oh well. Thanks for the insight.
    07-05-2015 10:21 AM
  1. Why does my new S6 keep restarting?
    By AC Question in forum Samsung Galaxy S6
    Last Post: 07-20-2016, 05:49 PM
  2. Replies: 2
    Last Post: 08-07-2015, 08:55 AM
  3. Replies: 2
    Last Post: 07-04-2015, 06:06 PM
  4. Replies: 1
    Last Post: 07-04-2015, 05:51 PM
  5. S6 stock email app does not save attachments when saving emails
    By Bokchoicowboy in forum Samsung Galaxy S6
    Last Post: 07-04-2015, 02:48 PM
