1. Snareman's Avatar
    I thought I had the option for different sounds for SMS and MMS a few phones ago, but can't seem to do it now. I'm using ChompSMS btw. Does anyone know if its possible to do?
    07-05-2015 03:01 AM
  2. emock81's Avatar
    The app you are using has to have the option to change the sound in the settings or it will just use the system default sound. I use Message+ and it allows me to change the sound.
    07-05-2015 10:53 PM
  3. Snareman's Avatar
    Thanks. i'll look into that.
    07-06-2015 03:09 AM
  4. Eclipse2K's Avatar
    Maybe I read the original post incorrectly but I think he's asking if he can use different sounds to differentiate MMS from SMS. I'm not sure if any application does this but I'm just throwing this out there in case someone knows.
    07-06-2015 04:05 AM
  5. Snareman's Avatar
    Yes, you are correct. Thanks. I read his reply apparently as fast as he read my initial post. Yes, I want one sound for SMS and one sound for MMS like I used to have.
    07-06-2015 11:44 AM
  6. emock81's Avatar
    Ah sorry for misreading it. Even then I would say the settings would have to be in an app. Never thought to do that because I get lot of group texts that come in via MMS so it really doesn't matter to me.
    07-06-2015 09:20 PM
  1. Replies: 0
    Last Post: 07-06-2015, 11:52 AM
  2. How do I connect my S4 to my Apple computer?
    By AC Question in forum Samsung Galaxy S4
    Last Post: 07-06-2015, 11:45 AM
  3. Replies: 0
    Last Post: 07-06-2015, 11:34 AM
  4. Replies: 0
    Last Post: 07-06-2015, 11:28 AM
  5. Replies: 0
    Last Post: 07-06-2015, 11:23 AM
