08-03-2015 05:26 PM
129 ... 23456
tools
  1. mobrules's Avatar
    Yea the only way I'm getting good battery life is I'm forced to turn 4g off and restrict background data. Which is the complete opposite of what this phone should be used for. Sad but true
    07-10-2015 05:37 PM
  2. Almeuit's Avatar
    That does sound bad .
    07-10-2015 06:44 PM
  3. mobrules's Avatar
    It is but unless I'm willing to give up UDP I'm stuck with it. Funny thing is my wife has us cellular and gets 5x the speed I get with big red. I just can't give up the plan. "from my cold dead hands".
    07-10-2015 06:49 PM
  4. JBerry0410's Avatar
    I used mine a lot today(just got it yesterday).
    6hr on screen time, all being internet on WiFi or playing Agar.io and I am down to 20%.
    I started the day at 7am and it is now 8:47pm and with like I said a little over 6hr of screen time. Also have has around 1hr of talk time.
    Certainly beats any other phones battery life I have used. This is also a pretty heavy day for me. I usually stick to 3-4hr of screen time.
    No idea if this is good or bad, but to me is seems really decent.
    07-10-2015 09:49 PM
  5. Almeuit's Avatar
    Agreed. If I had an unlimited plan w/ VZW I would not give it up for anything.
    07-10-2015 09:58 PM
  6. PowrDroid's Avatar
    I did a cache wipe last night then charged the phone completely and removed from charger at 11:30 pm and let it idle overnight. 10 hours later it was at 91% charge, That's only 0.9% per hour. That's more like it. Those 4 Android processes are still taking about 20% of the battery usage. Will continue to monitor it.
    After 13 hours I'm down to 54% remaining. Screen on time was only 2 hr. 35 min. Phone calls took 32 min. Those 4 Android processes are taking a bit over 20% of battery. Not happy with this. Looks like factory reset is in my future.
    07-10-2015 11:34 PM
  7. 88horizon5speed's Avatar
    Ok yesterday my turbo got only 16 hours on time before the battery got to 23% and thats with only 2 and a half hours screen on time....I just did a cacahe wipe of the phone. Im sttting to get annoyed at the crappy battery life. On kitkat Id go two days and sometimes 3 and with the same usage im getting only 1 day...
    btw my cache wipe took maybe 7-10 minutes
    07-11-2015 06:23 AM
  8. PowrDroid's Avatar
    Our experiences with battery life after Lollipop are very similar. And we are two of a handful of people on AC that thought the camera was very good. Coincidence? LOL. Who will be the first to do a factory reset?
    88horizon5speed likes this.
    07-11-2015 09:12 AM
  9. rxgadget's Avatar
    I am a heavy user. Primarily emails, texts, Web all day long. Yesterday was the first day I tried to not charge the battery till I hit 30%. I lasted about 8 hours. I was in a couple of low 3G areas and sometime at home on Wifi. I have never been able to get more than this with my old Samsung SG3 with Seidio 3500 size battery or the Turbo with 3900. The big differences with battery life are I can carry a QC 2.0 external charger if I travel for the Turbo and fill the to top it off if under 50 % or an old 1.0 amp charger and wait forever.
    When I tried my wife's LG3 I get about 6 hours. She gets 7 hours on hers. But just like the SG3 I mentioned we could swap out batteries.
    Sent using my Verizon Turbo charged 64GB Ballistic Nylon phone unfortunately with a case on back
    07-11-2015 09:59 AM
  10. rxgadget's Avatar
    Next thought. I have my old SG3 and an old DNA I know use either or both to play games or stream video or music and save Turbo for the rest.
    07-11-2015 10:00 AM
  11. rxgadget's Avatar
    07-11-2015 10:05 AM
  12. PowrDroid's Avatar
    rxgadget, what do you set your screen brightness at?
    07-11-2015 10:09 AM
  13. doogald's Avatar
    Unless you install apps from outside the play store, get rid of McAfee security.
    07-11-2015 10:31 AM
  14. 88horizon5speed's Avatar
    Well I tell you what, unless I'm getting 3-4 days from doing a factory reset I won't be the first! My battery life today seems alot better. Too early to say back to the very good normal from before but it could be. 10 hours on battery with an 1 hr 45 m screen on time and I have about 73 percent. It's important to know I am in a yellow to red cell zone 90% ofbthe time...
    07-11-2015 04:36 PM
  15. Emporess Amanda's Avatar
    I did do a factory reset and it did not help at all
    tonyr6 likes this.
    07-11-2015 05:52 PM
  16. JJ Jones's Avatar
    Initially I only did a cache wipe after the upgrade, and something just seemed off. So I did the FDR a couple days ago.
    Yesterday was a light usage day, but battery life seemed much more in line with where it used to be.
    Attached Thumbnails DROID TURBO 5.1 Lollipop: Battery Life after Update?-263.jpg   DROID TURBO 5.1 Lollipop: Battery Life after Update?-265.jpg   DROID TURBO 5.1 Lollipop: Battery Life after Update?-264.jpg
    07-12-2015 09:55 AM
  17. scooby8611's Avatar
    I must be doing something wrong. Mine was at 32% the other night when I fell asleep....about 8 hrs later, it was dead
    07-13-2015 11:27 AM
  18. venture996's Avatar
    I did a factory reset yesterday because my battery life after the Lollipop update was awful. That made everything better for me. I'm shocked, but it is very noticeable. The past week I was down below 50% of battery by mid-afternoon and today I am around 75%. That convinces me it was worthwhile.
    07-13-2015 02:50 PM
  19. Billy Bixby's Avatar
    Battery life is outstanding for me, slightly better than kitkat. No factory reset just wiped cache. What an awesome battery . Heavy use all day gives leaves me with 50-60% when i plug in at bedtime. Love L.
    07-13-2015 09:45 PM
  20. leehardballer12's Avatar
    I was one of the dummies that posted my battery life seemed a little better the next day after updating.....it is NOT better. I seem to be down 10- 15% from where I would normally be by the time I leave work. Not very scientific, but it is a noticeable difference. I'm having to use my car charger now so I don't run out before the day is over. Even on heavy usage days where I would watch HBO, or with heavy Internet surfing, my Turbo had no issues lasting until midnight. Battery usage actually now seems similar to when I would forget to switch the brightness back to auto. (I like to set the brightness higher to enjoy the beautiful screen while watching video) I know there is a setting that says the brightness is automatic, but now I wonder if it's really working..
    adayoff and Phoenix212 like this.
    07-13-2015 11:17 PM
  21. Shipmstr's Avatar
    My battery life after 5.1 was better than on KK. It is outstanding, however, after clearing the cache. It is simply phenomenal. This phone rocks!
    07-14-2015 01:21 AM
  22. mimsiesboy's Avatar
    Great, wiped the cache
    07-14-2015 06:29 AM
  23. PowrDroid's Avatar
    Caved in and did the factory reset. Next day took the phone off the charger (100%) and went to work. Didn't use the phone much for 2 1/2 hours (one 3 min. phone call couple of glances at other stuff, screen on was only 7 minutes) and when I looked at the battery it was only down to 98%!
    After I installed Lollipop and before I did anything else, 2 1/2 hours of inactivity would have set the battery down to 94-95%.
    Have recharged to 100% and will see what happens in real world use.
    07-15-2015 11:26 AM
  24. MA2GA28's Avatar
    I did a cache clear yesterday, then charged to 100%. After almost 16 hours (2:15 screen time) I am only down 30%. The cache clear is looking like a big help as well.
    07-15-2015 11:38 AM
  25. mobrules's Avatar
    Keep us updated please. Curious to see results. Thanks.
    07-16-2015 08:52 AM
129 ... 23456
  1. Replies: 1
    Last Post: 07-06-2015, 06:43 PM
  2. Why won't my Samsung Galaxy Tab2 not turning on when full battery?
    By AC Question in forum Samsung Galaxy Tab 2
    Last Post: 07-06-2015, 04:42 PM
  3. HTC One M7 No OS after Flashing Recovery ROMS on TWRP
    Last Post: 07-06-2015, 04:38 PM
  4. Replies: 0
    Last Post: 07-06-2015, 03:13 PM
