1. PowrDroid's Avatar
    Found a function in an app called AutoMateIt that no longer works with Lollipop. I had created a rule based on Set Mobile Data Actions so that when I left my house (got disconnected from my WiFi) my Turbo would automatically turn off WiFi and turn on data and Bluetooth. When I got back home it would turn on WiFi and turn off data and Bluetooth.
    This is now broken. Bummer. I really liked that automated function.
    07-04-2015 05:48 PM
  2. vzwuser76's Avatar
    It's quite possible that the dev for the app needs to update it to restore functionality. Maybe try contacting the dev and see what he says.
    PowrDroid likes this.
    07-04-2015 07:41 PM
  3. mobrules's Avatar
    Powrdroid same issue with Tasker.
    07-05-2015 07:59 PM
  4. maddiealan's Avatar
    I use MacroDroid and I had the same rule set on my Turbo. Unfortunately, it doesn't work there either. However, I'm very happy with everything else. Battery is great, phone is speedy, so I'm happy with Lollipop 5.1.
    07-06-2015 12:11 AM
  5. doogald's Avatar
    I'm guessing that android removed the ability for third party apps to turn off mobile data, just as they earlier did for airplane mode, perhaps to prevent malware apps from turning off data to prevent the malware from stopping remote data wipe from android device manager, etc.
    hub1 likes this.
    07-06-2015 01:54 PM
  1. Lolipop for SM-P900 is ready for dowload in US.
    By cperrry1 in forum Samsung Galaxy Note Pro 12.2
    Last Post: 08-27-2015, 01:54 PM
  2. my android camera not working how to fixed it
    By adelynddatuin37@gmail.com in forum Ask a Question
    Last Post: 07-06-2015, 12:55 PM
  3. I can send a text but it will no receive one. Help
    Last Post: 07-06-2015, 12:18 PM
  4. Replies: 0
    Last Post: 07-06-2015, 11:50 AM
