07-26-2016 06:48 PM
36 12
tools
  1. Karl Turbo's Avatar
    I'm 54 Karl. Get with the program. (I'm just messing with you by the way)
    Darn, you're wicked old.
    dungoyle likes this.
    07-13-2015 12:13 AM
  2. Almeuit's Avatar
    Mod Note - Some posts have been cleaned. Let's remember to follow P.U.P.P.A.H.
    Thanks.
    07-25-2015 02:13 AM
  3. smokie11's Avatar
    You have to be an FSU graduate for the chop to work.
    KSDroid01 likes this.
    07-27-2015 07:14 AM
  4. Clocks's Avatar
    Don't use your wrist, use your arm. It's a "chop chop" motion like a tomahawk, not a "flick your wrist" motion like you're waving.
    (a really hard/fast wrist chop works too, but it's more reliable for me without using your wrist).
    07-27-2015 02:03 PM
  5. procrastination's Avatar
    The Flashlight chop seems less than perfect. I had a lot of trouble getting to work at first, but it seems a little easier now.
    Works every time for me.
    Think: "flash-light-on" while chopping.
    http://i.imgur.com/VDS9TY0.gifv
    Sent from my XT1254 using Tapatalk
    maxman1 likes this.
    07-27-2015 07:52 PM
  6. Karl Turbo's Avatar
    Works nearly every time for me today. I wonder if the post lollipop update had any effect on it?
    07-27-2015 08:23 PM
  7. Giddy da gamma God's Avatar
    Anybody get the flashlight chop to work? Doesn't work for me
    Y'all are nuts this **** works first try its called chop chop. Hold it in your hand normally rotate your wrist so one side (edge) yall will confuse that with front and back...bsi yea rotate so its got one side facing the ground and logically other towards the sky. No do a fluent and strong choo like your using a hammer. Idk how you guys are having trouble once you know what to do. Don't make it a short motion. If so the phones calibration will not now if ur trying to use camera the only fact is how u start the chop with the phone screen facing the wall will tell your phone the chop chop for the camera is about to happen. If you do it to fast the flip then chop its confused and it will not allow either to happen.. Made it long lengthy and explained for all if you so u can use this feature. PS its retardedly simple don't get all flustered and spastic or you'll screw it uo.. Good luck turbo fam
    01-29-2016 03:09 AM
  8. PowrDroid's Avatar
    Yes, Giddy.
    However, I had no idea that the same chop-chop motion also turns OFF the flashlight until my son showed me. Previously to knowing this, I had been swiping down my windowshade then turning off the flashlight.
    01-29-2016 12:02 PM
  9. Bitterman's Avatar
    Works fine for me on lollipop, although you have to do it pretty hard to get it to work. I'd just rather use the drop down...
    01-29-2016 12:18 PM
  10. sameat's Avatar
    I know this is ancient, but I got mixed results with the chop until I stumbled across the following tip:
    Chop like buzz lightyear.
    Worked much better once I started doing that...it's a more rigid motion than I had been using, with almost no wrist action.
    02-06-2016 01:25 PM
  11. Finn Henderson's Avatar
    If you have a magnet lock case, it can't be closed.
    07-26-2016 06:48 PM
36 12
  1. Lolipop for SM-P900 is ready for dowload in US.
    By cperrry1 in forum Samsung Galaxy Note Pro 12.2
    Last Post: 08-27-2015, 01:54 PM
  2. Replies: 1
    Last Post: 07-06-2015, 11:58 AM
  3. Where do I find the Lollipop rom for my HTC Desire 600 dual sim?
    By Nitish Lall in forum Android 5.0 Lollipop
    Last Post: 07-06-2015, 11:41 AM
